0 Members and 80 Guests are viewing this topic.
NickZ
  qoute:
  "There is a difference guyz.
We need pulses ( beating heart) ( Swing ) but not High frequency oscillations.
    But, how 'bout  those pics and videos that you promised,  and some explanation of how you tuned your set up, to get it self running.
  And also, can you explain how the circuit that you posted, which was further simplified in the diagram by MenofFather, works. Without needing the high frequency Kacher circuit as well,  that you say is NOT needed?
What is beating, pulcing, swinggin, etz with what then?
  Akula is using kachers to superimpose the VH pulses onto the air coils secondary Ac output coil. Or not?  Your system works differently?
  It's more motivating for us, if you show us what you mean, and have built up.
corry
Vietato Fumare
23 ore fa
+Victor Gero
Таким образом, результат выходной выше у входа? (Over Unity?) Простите, но я не понимаю русский язык. Спасибо.
Rispondi
Victor Gero
23 ore fa
Нет. У этого устройства кпд меньше 1. Извините если это видело привело вас в тупик!
Translate:
Vietato Fumare
23 ore fa
+ Victor Gero
Thus, the result of higher output at the entrance? (Over Unity?) Excuse me, but I do not understand Russian. Thank you.
Rispondi
Victor Gero
23 ore fa
No. This device efficiency is less than 1. Sorry if you saw led to a dead end!
https://www.youtube.com/watch?v=yKjgMmZcFA0
Tomtech29
hello.
I am here for the first time are moving very interesting topic,I know poor English language I'd like to thank for work done.
how can I add something,I think the measurements are wrong there is 113KHz.
-field Operating Noise is distributed
-measurement of only one cable from the tester?
-200W. and this 40 watt bulb with the power supply 2 Amper.z the same brightness?
well gentlemen I can I do not know but to me it does not fit
-drill revolved much slower and idling without resistance force?
I'm willing to admit right "Itsu..."
quotes:
Concerning this 113KHz frequency being used in the original clip, this can only be created by drastically lowering the capacitor from the used 1.1uF (2 x 2.2uF in series) to about (100nF).
I might add that these are not ceramic capacitors  the way,I think so and that the sea be a problem what do you think?
I suppose a large coil are:(polyester capacitors audio) and the small coil is oil capacitors! and as much as I see it for you and not the other?.
greet and enjoy. :)
https://www.youtube.com/watch?v=Ip1JHPyAtTY
Hoppy
Quote from: NickZ on July 20, 2014, 01:35:59 AM
  qoute:
Nick,
There is no guarantee that Akula is using a working Karcher in his garden demo, its probably just eye candy.
With respect to Geo, the schematic he posted with the three oscillator elements cannot possibly self-run by disconnection of the power supply. However, its supply battery may appear to charge whilst running a load and this may be what is giving Geo some reason to be hopeful that a true self-runner can be achieved. However, I see no reason why Geo cannot at least post a video of his current device to show how he has built the three oscillator elements and show how the Karcher element is affecting operation and the generation of the 'heart beating' type pulses, whilst powered from a battery.
itsu
Quote from: magpwr on July 19, 2014, 08:47:51 PM
hi itsu,
Thanks for the doing all the necessary measurement as shown in video .
I just did a search this Sunday morning and found that a Russian forum was talking about this VICTOR - VC9808 series multimeter.
This device was used in the video being discussed which i merely suspected to produce "erroneous reading" related to the frequency.
Youre welcome,  thanks for finding that out, combined with the fact that only 1 lead was used measuring the 113KHz i am sure it was false.
Thanks itsu for assembling the device.I hope your efforts did not go in vain after learning something from experience.
If i got the time today  i will setup and upload the original donsmith device which was successfully wrapped up months back to demonstrate the 1/4 resonance at <100volts input to show there is no real effect on primary current during shorting test at output.
No problem,  its my pleasure and indeed learning a lot on the way with your guys input.
Good luck with your DS setup.
Regards Itsu
