0 Members and 850 Guests are viewing this topic.
Utopia Now
Yes I also thought that the frequency of the coil probably was 40 kHz ..   as i mentioned earlier on page 313 , in this post
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg409556/#msg409556
QuoteI count 10 turns ( 5 blue and 5 brown windings ) and if the Coil dimensions "maybe" are about :   diameter : 15 cm and length : 8.6 cm    than this online Coil inductance calculator gives :  14,4 uH
http://www.66pacific.com/calculators/coil_calc.aspx
If we than want to find de LC resonance frequency with this online calculator (  http://www.daycounter.com/Calculators/LC-Resonance-Calculator.phtml  )
We get 14,4 uH  and 1.1 uF  ... this gives a LC res. of  40  kHz      which is the freq  that  was also  shown on the meter in the video .. measured from the thin coil inside the big coil  ...
here an other online LC res  calculator  http://www.ekswai.com/en_lc.htm
For GeoFusion :  I would Love to understand what you mean better ...
QuoteThere is a difference guyz.
We need pulses ( beating heart) ( Swing ) but not High frequency oscillations. :)
Can you tell us more , that would be nice.
The (tekst) info about the working principals is from   00   its in my online Prezi document ... see the 2 pictures below.  http://prezi.com/fiwgtl78it85/donz-device/
magpwr
Quote from: itsu on July 20, 2014, 06:41:56 AM
Youre welcome,  thanks for finding that out, combined with the fact that only 1 lead was used measuring the 113KHz i am sure it was false.
No problem,  its my pleasure and indeed learning a lot on the way with your guys input.
Good luck with your DS setup.
Regards Itsu
hi itsu,
It's Sunday 8pm over here.
I have just  uploaded my Don Smith device basic setup video  for you guys with the scope.This is my first uploaded video after around 3 months as i was busy designing a more advance version of Don smith device.
http://www.youtube.com/watch?v=z-MZSavyM8U
My solo presentation skill isn't great.But what i am trying to show the world is that by applying "1/4 resonance frequency at one of don smith secondary CW or CCW coil" of the primary L/C resonance frequency.
I am easily able to show a short-circuit test at secondary rectified output without even effecting the primary current drawn from battery.(This is how it suppose to be done like those bulbs in parallel which almost looks like a short-circuit for those high voltage version)
It's very hard to show sparking at secondary output and observe any surge watt meter reading in one video frame window as i do have space constraint unless i put it all on the floor.
The current as controlled by duty cycle to mosfet stayed around 0.6Amp even during permanent short-circuit test at output.
Don smith device is intended to be powered from high voltage high frequency at the primary coil.For quick demonstration i merely use 12volts battery with high frequency 228khz.
In due time i will be revealing the high voltage version.
Secondary coil spec  8cm diameter pvc pipe ,12AWG 17.5 turns CCW&CW around 14.15uH for each winding less than 0.8uH difference between 2 coils at secondary.
Primary coil 8AWG 5 turns spec=2.4uH
Primary L/C:2.4uH/0.21uf(HV) to get 222khz if no capacitors connected at secondary yet since it's the primary resonance that determine the secondary 1/4 resonance.
Upon connecting combine capacitor 0.59uf(HV) to one of Don smith secondary coil L/C:14.15uH/0.59uf .To get close to 1/4 frequency of primary resonance of 222khz which is around 55khz.
But at this point primary needs to be driven at 228khz little higher than 222khz to get to see maximum peak to peak voltage on 5 turns primary coil using less than 1Amp from 12volt battery.
For low voltage demonstration i am merely using inbuilt dual diode-MUR3060PT at the secondary coil.The center from the diode is rectified (+) which was connected to 5uf capacitor(optional induction heater capacitor).
For short-circuit test i am using 50volts 10,0000uf capacitor in parallel with optional 5uf which was already in place.The center where 2 CCW,CW coil is merged will be the (-).
I did not show the reading taken at the 0.59uf capacitor located on the secondary coil this is running at around 2Mhz using just 228Khz input at primary.
The primary coil merely needs to be shifted inside the large pvc pipe for maximum voltage rise and still maintaining stable current drawn <1Amps from battery.
You have shown me that you are one of the possible 2 or 3 members in this forum i know off whom will be capable to replicate my future advance version of Don smith device for the purpose of verifying device by replication.
I have attached my hand drawn version.This experiment was actually conducted few months ago but i did not create video.
a.king21
Quote from  Geofusion on the Barbosa thread:
Quote from: nelsonrochaa on July 19, 2014, 01:34:00 PMPeople one post more    is weekend and im happy
I want to put a link of one my new subscription of youtube Gfusion Core.sa
link [color=rgb(27, 142, 222) !important][size=10px !important]channel[/color][/size] https://www.youtube.com/channel/UCyZZNOLvFRlSMnloejp3Cw
Man if you listen me you make a great work! proving that all i say about isolate from the conventional principles of electricity if people want to advance is like [color=rgb(27, 142, 222) !important][size=10px !important]this man[/color][/size].
I recommend i have great videos about ground system , [color=rgb(27, 142, 222) !important][size=10px !important]high frequency[/color][/size] energy and other great thinks  .
bye
[/size]
Hi there nelsonrochaa !
Thnk you for your nice comments, yes I have been doing alot of Experimenting for some years now, Have you seen my videos??
Check them out.
I did many experiments with coils and Tesla coils, Royer circuits , and other [color=rgb(27, 142, 222) !important]types of[/color] transformers with pulses.
https://www.youtube.com/channel/UCyZZNOLvFRlSMnloejp3FCw/videos
Btw I have seen that you got a Captor, was very interested to hear about this.
I also did some tests and the results are odd yet surprising.
I did replicate a small captor based on what was provided in this thread, and saw that the Fase (hotwire) works with ground very good and
depending how many grounds you connect to each other like I did, managed to [color=rgb(27, 142, 222) !important]pull[/color] 2.0~ amps from ground and voltage around 90V.
I  connected e bulbs of 200 watts ( each 100watts )
I have 127V here on the island.
I managed to put plates in ground, 3 plates  of half a meter wide and half a meter long.
Good output, but the more plates I put the more amps and maintains voltage up. But can't touch the ground haha.
But don't know if the meter can count that what I am using.
I will check your videos out,  Because There must be methods of creating a a Hot wire via e inverter that can pull out amps like how I do with the mains hot wire.
Cheerz , Hope to share more
Is there no limit to Geofusion's genius??
NickZ
  Hoppy:
  Akula did mention in the video of the second device that he has HV running through the 3 inch ferrite rod. Although we can hear the spark on the camara, as he touches the lock or spark plug to the rod, the spark is not the same (sparkler) kind that was just posted in the picture above (Chinese replication). So, it's not very high voltage, but maybe a lower amp type of spark which makes some noise, and can also effect nearby electronics. And that spark does NOT shock him, at all. Or he is superman...
  That was the video device that was confirmed WORKING! I'm working with that schematic, as well. But, can't see how the 3 turn yoke coil can produce enough power to light and of my bulbs. Therefore I'm using the yoke secondary output coil to connect my bulbs to. And using the yoke 3 turn coil going a rectifier/capacitor, as the feed back path. My joule ringer exciter is not working at the moment, as connecting it to the yoke secondary output fried the transistor(s)  So, I'll connect up the way that Akula showed, instead. Just trying to see if I find the right combination of wiring connections that will allow my Mazilli to work with the Akula coil set up.
Hoppy
Quote from: a.king21 on July 20, 2014, 10:20:32 AM
Hopefully we will find out when and if his video appears.  ;)
