0 Members and 2012 Guests are viewing this topic.
Hoppy
Quote from: itsu on July 24, 2014, 06:31:10 AM
Yes, i used a single turn on a nanoperm core (55uH), but with that it went straight into special mode.
Repositioning the choke physically at the input and changing the 470 Ohm resistors for normal metal film ones does not change much.
So i am still puzzeled about this special mode, with the big air core coil (Leader Genie replication) it never does that with each choke i tried.
Guess its something introduced by the ferrite or the split (mechanical resonance?) of the yoke, or simply the higher inductance.
Regards Itsu
Thanks for your reply Itsu. I will at some point re-build my mazilli and see if I can create the 'special' effect and investigate.
Hoppy
Quote from: magpwr on July 24, 2014, 07:33:08 AM
hi itsu,
May i suggest something which would assist you to secure this special mode 100% of the time.
Once you get yoke running in special mode and then try placing probe nearby or connecting probe .
Once you have discovered the special mode frequency the yoke is running.Apply this by assembling a pwm generator to recreate the signal to feed the 2 mosfets at the primary coil.
The question where do you want to go from here like how you plan to connect to another main coil on pvc pipe.
Hi magpwr,
Are you suggesting that the 'special' mode with its high current consumption and hot mosfets, is in some way important to achieve as a stepping stone to self-running and if so, why?
magpwr
Quote from: Hoppy on July 24, 2014, 11:18:44 AM
Hi magpwr,
hi Hoppy,
My honest opinion Yoke setup in itself won't get you far.
There are so many Akula variant device.
I am merely mentioning 2 on how i recall the yoke was used as per those schematic of Akula released in the past.
1)Yoke setup is used as cheaper alternative as compared to 12volts to 220volt inverter.
2)Another way i have seen the rectified output from the 220volts inverter (+) connected to yoke primary middle coil and driven by 2 igbt by pwm generator TL494.
   The secondary output is consisting of just few turns which is connected to the large pvc pipe.
May i ask how are you planning to interface this secondary yoke coil to the main coil?
If you are just focusing on using yoke coil with mazilli to find the special frequency to give you optimal output.After which you will still to construct pwm circuit with fixed frequency to automatic run yoke in special mode without frequency drifting which mazilli circuit would likely do.
Using pwm circuit would allow you to control duty cycle at same frequency to limit output or limit current drawn.
The reason why i stayed away from Akula device because there are alot of missing information for me to proceed.
If you downloaded the july pjkbook.pdf at page 277.
There are new finding in China related to Don smith and do watch his setup as spoken in English.A very unique learning experience.
Hoppy
Quote from: magpwr on July 24, 2014, 11:31:23 AM
hi Hoppy,
I have done much experimentation over a few years using various PWM circuits interfaced to all sorts of coil arrangements. All of these setups have proved very inefficient, which is why I'm so negative about most of the circuits and self-running claims I've seen posted on the forums. I have no pre-conceived plan for interfacing the secondary yoke coil to the main coil. I will simply try various arrangements to seek the 'special mode' with the Mazilli, which I have mainly used for induction heating experiments.
NickZ
  I agree that there is lots confusion as to how the Akula second video device, also replicated with success by Ruslan, works. As neither of them are really showing how they built it, or just how they got it self running. So, we may have to do our own experimenting. But, we see that these devices can be maid to self run, I think that the time spent will be worth it, in the long run. Hopefully not too long, though.  And, I think that if we get on the same page, we might have a chance at it.
  What Itsu is calling special mode, to me is the normal mode, which has the higher output. And also of course,  the higher current draw.
Only when the device is not in resonance,  and is not running at its best frequency, or with unmatched bulbs load for that frequency, or if inadequate voltage or current is being supplied, do I get the lower (not normal , for my circuit) operating mode. Otherwise it is always on the normal brighter bulb lumin levels mode.
   I would love to see Hoppy get his Mazilli crt going again, or connect the yoke to a nano pulser unit,  and all connected to the Akula-Ruslan type air coils core. Pre concieved, or not...
Or maybe Itsu, or anyone else with a adjustable pulser unit.
  BTW. What happened to Grum?
   My previous set up is all changing now to the Akula-Ruslan-TK type of output air coils, but still with the Mazilli-yoke providing the magnetic inductive kick, which is now also going and is connected to the air coils.  I will show that set up soon.
  In the meantime, here is a pic of my last effort to heterodyne these two frequencies together.
