0 Members and 85 Guests are viewing this topic.
T-1000
Quote from: Jeg on September 21, 2014, 09:46:54 AM
Is it possible to attach the link of this specific akula's video please?
https://www.youtube.com/watch?v=-rALEpvBQig
Quote from: NickZ on September 21, 2014, 10:56:29 AM
  Ruslan and Akula are now using very different set ups.
They both are using same thing just different mods for high voltage nanosecond and automatic resonance frequency tuning circuits .... ;)
magpwr
  The big white coil is not what is being used in the schematic, or on the device.
The tesla coil is the one with the magnet wire, going to the ferrite rod, then to the thick coil antenna. Tesla coil primary is the 5 to 6 turn thick primary with the oscillator connection in the center of it.
I hope that was what you were wondering about.
  Ruslan and Akula are now using very different set ups.  I would personally go with Ruslan's way of doing it, as it's simpler, and still can produce about 2.3kw.
The difficult part of their circuitry is the duty cycle/frequency modulator circuits.
I wish that that those units could just be purchased, instead.
Hi nickz,
It's good news we can ignore Akula video and his tesla coil which was meant for older version of his device i guess. ;D
Pwm circuit based on 3825 can be assembled for less than 10 dollars.
Operating a pwm circuit is simple always set duty cycle to zero before powering on before connecting to mosfet.
But scope is needed since high freq which we cant hear.
MenofFather
Quote from: magpwr on September 21, 2014, 10:37:32 AM
Hi,
I am unable to co-relate thick tesla coil winding with this circuit diagram in the video.
Do anyone know where tesla coil with thick wire belong to if compared with winding shown in circuit diagram.
There isn't a clear indication which is the tesla coil in the drawing.
Although it seems obvious this tesla coil layer need to be the first layer,if i am right to mention.
This thick tesla coil was also seen as standing pvc pipe in older video before the winding is completed.
Can anyone please advise  where is this thick  tesla coil in circuit diagram as seen in this video.
We need fit all the missing puzzle together with no doubts before even thinking of replication.
In the meantime i am waiting for expensive capacitor and air coil to arrive for don smith.
Valuable time is lost yet again due to long delivery time.
That means tick tesla coil, tick secomndary or primary?
magpwr
Quote from: MenofFather on September 21, 2014, 01:30:38 PM
Hi MenofFather and everyone(whom is not skeptic about overunity),
What i am trying to say is Akula is now showing how he is doing the tuning on the tesla coil which is using electrical wire.
The video actually needs to be related to the older device.The device which was done outdoor on the table with one pvc pipe which is placed in standing position.There is a actual 220volt inverter along with yoke core for this version.If i recall correctly this device was the 700 or 750watt version.
This is only half the setup or half the story.I will explain more below.
This is my latest findings based on Ruslan device setup using his video
http://www.youtube.com/watch?v=7j7Y6sBnGV8&list=UUwVT-3hF29an4vZOz7nGOwg
Please refer to attachment-
This is my 1st run of reverse engineering the Ruslan coil setup as attached without the deeper level of verification done yet.
MenofFather we need your help to translate Akula video as shown below in details because it is the left coil which i called "the thick Tesla coil" to simplify remembering and identifying.
This is important piece of the puzzle revealed by Akula which is using the Earth. :D :D :D
http://www.youtube.com/watch?v=-rALEpvBQig
Base on the video i recall someone mentioned it the 3rd harmonics which was being used to tune the thick tesla coil.
MenofFather please help us translate.I am still little lost since i don't understand Russian to understand what Akula is saying.
Please tell me what Akula is telling to get this tuning right or what kind of waveform we need to see.Please use the above video and capture for me the correct waveform which we need to see.
Base on attachment-
Everyone just remember at the left side of the coil(Thick tesla coil) is the transmitter portion and the right hand side of the device is the receiver portion which is the multi-layer coil(eg:48,48,24,24,12,12).
This my Strategy which is to find how coil is wound first before even thinking of the electronic circuit.We got the tuning the left\tesla coil video by Akula in Russian which needs to be
professionally translated to English so that i can decode\understand better which can be replicated using the provided circuit by Ruslan or Akula to generate the required waveform from the left side\thick tesla coil which is the obvious magnifying transmitter.
The center connecting wire which i called the transmitting and receiving antenna is a straight cable this time but notice carefully the outer coil(both large looking coil which consist of few turns) for the left coil and the multi coil located at the right side of attachment is connected in cw,ccw formation for the 2 outer coils.
starcruiser
@magpwr,
Can we determine the output of the kacher/telsa coil, voltage wise? is it only a few thousand volts? or is it 10's of thousands? I think it might be less than 10k, thus would a simple HV source be enough to create an impulse generator?
Regards,
Carl
