0 Members and 610 Guests are viewing this topic.
d3x0r
Quote from: verpies on October 29, 2012, 03:27:08 AM
( a math trivia for you: What is the current flowing through the resistor above? )
P.S.
100W resistors are likely to be wirewound and hence inductive.
Inductive resistors are unacceptable as Current Sensing Resistors (CSRs)
120A... E/R=I ... P/E=I
Ya, these are metal film, digikey has category 'current sensing' which is also 'low inductance' which are on the order of 0.1uh and less...those are from that category;  They had one that was just a alloy metal bar, but they are out of those.
those that I linked are $12.54 each though... can get 3W and 5W ones... for a dollar or less
d3x0r
Quote from: verpies on October 29, 2012, 06:48:34 AM
According to this, these кд203A diodes can withstand 420V of reverse voltage.
This would mean that for them to work in avalanche mode (not DSR mode) they would require more than 420V to break down.
Maybe, just maybe the W2 of Tr1 could provide sufficient voltage for this, if Tr1 worked as a saturated flyback transformer.
Did anyone ever ask Dally whether he intended his кд203A diode to work in avalanche or DSR mode?
...or did he drive the base of his KT926 transistor directly from the TTL Integrated Circuit or via some intermediate transistors?
Vasiliy, Cергей, anyone?
but TR1 is capped at 150 by the neon...
verpies
Black_Bird
@d3xor
The function of the neon is simply an indicator that the inverter is powered up, nothing else. With a series resistor of 100k, there is no regulation function attributable to the neon.
madsatbg
Hello
so it seems fitting perhaps a nanosecond generator.
By courtesy of Сергей-в.
