0 Members and 307 Guests are viewing this topic.
itsu
Quote from: MenofFather on October 17, 2014, 01:59:30 AM
:) Yes. That capasitor in series with multi layer coil is not resonase capasitor, it is coupling capasitor.[/size]
Only in this two points (I get only on 900 kHz and 4 MHz)?
As i mentioned earlier:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg419357/#msg419357
i measure the following resonances
(sine wave signal when inputting 5V square wave):
   944 KHz 20Vpp
2.115 MHz 10Vpp
3.965 MHz 12Vpp
Inductance measured then:
100Hz    146uH
1 KHz     146uH
10 KHz   145uH
100 KHz 87uH
Regards Itsu
itsu
Quote from: MenofFather on October 17, 2014, 02:06:31 AM
Well done! Try inreace pulse lengh going to transistor gate. To get 100-300 ns pulse.
And inductor (bifilar coil, of two layers) must be grounded. And it must be on top coaxial cable, better maybe mount tube on coaxial cable and then wound inductor.
You can try that setup:
I tried grounding the bifilar 2x 25 turn coil, but no difference seen.
For the coax inbetween the bifilar (2x 25 t) and the grenade coil i have to do some partial rewinding.......
Regards Itsu
MenofFather
Quote from: itsu on October 06, 2014, 08:18:31 AM
When i do that (multilayer coil grounded at one end, the scope probe across this coil), a measure the following resonances
944KHz 20Vpp
2.115KHz 10Vpp
3.965KHz 12Vpp
So you get 3 frenquencies on multilayer coil?
2.115KHz it seems that, about that speaking Ruslan.[/size]
:D
MenofFather
In all Ruslan divice seems 2 layers coil (bifilar) wounding begining is at that point at that is multilayer coil wounding beggining.
itsu
Quote from: MenofFather on October 17, 2014, 07:49:22 AM
:D
Yes,  3 distinct peaks, there are more, but much lower in amplitude.
Regards Itsu
