0 Members and 355 Guests are viewing this topic.
Hoppy
Quote from: Jeg on October 19, 2014, 08:22:39 AM
Thanks man. I just modified my previous answer. Just saw the video again. Any ideas about his input choke?
I have an identical one and as wired its inductance is in milli-henries, not micro-henries. If you look carefully, you will see that he has re-wound it with what looks like thin PVC covered wire. I did this and got the inductance down to around 300uH. I doubt whether his is as low as 100uH as shown on the circuit. My choke came from a stripped down SMPS and it is a common mode type.
magpwr
hi everyone,
I have just created a simple prototype high frequency divide by 60 circuit in the virtual at this moment using just 2  I/C 74HC4017.One doing div by 6 and another div by 10.Total div by 60.
Maximum tested frequency at 10Mhz although i don't need that high.
Recall the waveform which i was talking about which is aligned.I found that by playing with signal generator at the lowest test frequency 18khz .The upper frequency needed is 1.075Mhz...1.08Mhz.
By referring to the Harmonics calculator it is always divide by 60 to get the alignment.
Currently i only got just 1 4017 I/C which is only able to handle up to 2.4Mhz base on signal generator.
The 4017 clock input is protected by 1N4148 to positive and negative supply.I just use a short wire as antenna and tested with my existing old tesla coil resonating at around 556khz.
The 4017 is able to properly div by 10 and produce nice waveform at 55.6khz.
This div by 60 is not completed yet since i just completed the basic design few hours ago.
The primary objective in creating this circuit is to ensure the tesla coil resonating frequency will always be divided by 60 via
small wire antenna and this output of div by 60 will be fed to the yoke driver at the later stage. :D :D :D
If i have it my way then i am no longer worried about tuning the pwm generator to match tesla coil harmonics.Since i just use tesla coil frequency to sync the
yoke driver at 60th sub-harmonics at the later stage.Or worst no need to worry about tesla coil run away resonating frequency.
This is my future planning since i don't have yoke/large toroid core yet.
My utimate plan is to fit all the circuit including the yoke/toroid core into one large pcb board.There will be various section in the circuit board.
The only component to be placed external would be the high energy discharge capacitor.
"Slowly all the puzzle will be fitted together at a quantum level to form this unit" ;D
Hoppy
There many chances for being zeners because as I told before, frequency and voltage level are closely dependent values between each other.
Jeg,
Yes, most likely a couple of  zeners / transorbs in series (cathode to cathode) across the collect / emitter.
Hoppy
Quote from: itsu on October 19, 2014, 05:39:58 AM
Thanks Enjoykin,
Guys,  take care NOT to use a lab PS when tuning/testing your Kacher, use a battery or a simple 12/24V PS.
Last night one half of my double PS went out with a big bang while tuning my new kacher  >:(
There is loads of RF going into your PS with the above result, the same warning i did read on the Russian forum last week or so.
Regards itsu
Good advice Itsu! I've repaired my dual channel PSU four times in the past playing with Bedini circuits!!
Jeg
Quote from: Hoppy on October 19, 2014, 09:24:07 AM
Jeg,
Thanks Hoppy, i appreciate it.
I saw somewhere in my scrap storage a similar choke. I am going to search for it.  ;)
