0 Members and 252 Guests are viewing this topic.
itsu
I tried the following method to "characterize" the grenade coil:
Use my FG to sweep a frequency range from say 10KHz to 10MHz.
Have my scope synced on the start pulse of this sweep and display the frequency response.
The screenshot below shows the frequency response of my grenade coil while attached in the circuit (not sure this is right).
You can see severall resonance peaks like first one around 900KHz, next one around 3.8MHz, and the biggest one at 5.3MHz.
I am missing my 2.1MHz peak which a have tailored my Kacher on  >:(
I also extended this to the full frequency range of my FG being 100MHz.
Then i checked the response of my 2x 25 Turn bifilar coil with the 0.47uF cap the same way and i do see a peak at 26KHz.
But also many more on much higher frequencies, so take it for what its worth.
Video here:  https://www.youtube.com/watch?v=_-HdHSvTX2Q&feature=youtu.be
I also had a chat with T-1000 which was in the teamspeak session with Ruslan and there it was told that the grenade coil
5th and 6th layers should have the same direction as the 1st and 2th layer, so basically all 2 layer pairs are wound opposite (CCW-CW-CCW or CW-CCW-CW)
I am planning to build a new coil with a measured 37.5M length that way soon.
Regards Itsu
magpwr
Quote from: T-1000 on October 20, 2014, 03:27:27 PM
You need to lower interwinding capacitance so the Tesla secondary coil winding spacing should be at least on every second turn. Ruslan used 0.8mm diameter wire(oxygen free) as he told in latest video https://www.youtube.com/watch?v=hpYj4YT_DIs
hi T-1000,
This oxygen free cable was mentioned for the actual multilayer winding by Akula .
Akula did mention if using oxygen free cable "1.5mm sq" and not using oxygen free cable "2.5mm" sq.
What i am trying to say it is not a 100% requirement as you can use thicker wire to compensate any lost.But i am strictly sticking with normal 20AWG insulated wire 0.81mm for the tesla coil.
[Yes there is improvement using oxygen free cable wire over non oxygen free wire.For example i was using Solid SILVER COATED OXYGEN FREE  30AWG wire for my Variable High Voltage DC power supply 150volts.This AWG30 cable outperform my 26AWG insulated copper wire and i am able to apply more turns and zero heating detected on wire.
This 30AWG wire can even destroy my 600watt TVS diode in one my project.
That video you linked is not a working unit.Recall the older video where he remove the electrical box while the unit is self running and there was 2 large PIO capacitor for the nanosecond generator inside.
Now he is trying to show a unit with no nanosecond and PIO capacitor which to me is a distraction from the actual stuff.
magpwr
Quote from: itsu on October 20, 2014, 06:22:20 PM
Regards Itsu
hi itsu,
You mentioned-
For the only kapanadze coil which i posted a photo I have mentioned i am just following the one of the Ruslan video which the winding spec can be clearly seen from the "naked eyes" which i trust better.
My winding spec was posted on my image of kapanadze coil photo.I have explained my reason why i need to use 60turns for the first layer previously in that posting provided if you are very particular like me to get the 10cm exposed.
T-1000
Regards Itsu
Well, I was listening to teamspeak session recording, not been there ;)
Also there are some opposing things about top layers winding direction as Ruslan did told to wind every single half to opposite direction in teamspeak but in
https://www.youtube.com/watch?v=iyDaVspeeNE#t=2m35 at 2:35 it is clearly seen the top half is winded on the same direction as previous. So it might to work on both cases just there is most likely question about which is better...
Enjoykin
Thamks you Itsu - You are nice fellow and good man.  :)
Watch Граната СЕ  - White OU Grenade.
http://www.youtube.com/watch?v=42j7gKCMIGU
Everything here is simple and perfect and in accordance with simple and truthful mathematic rules.
I think starting winding directions have equal validity. Both sides are equivalent. Right-Left and Left-Right. What is really important here, for wave resonance is lenght of wire and of course form of winding.
ps: I have an idea for next Grenade coil making it from excellent insulating enameled Litz Wire 2.5mm2. This shoud be tested.
Have a nice experiments !!
All best !!
Reg.Enjoykin
