0 Members and 409 Guests are viewing this topic.
skywalker66
Quote from: Enjoykin on October 20, 2014, 04:35:02 AM
Man called Denny from our Russian forum has caught OU effect - but only 60W power for free. What is interesting is he was excited not bifilar inductor but Grenade coils layers 5 and 6.
Now he rewounded coils so will see does he wiil catch OU effect again or not !!
his video
http://www.youtube.com/watch?v=hlLLiwzfoeE
________________________________
Hello ! That is most interesting my friend. I wish to know more about this experiment. Can you please provide more info about this setup ? or a source of it? It seems to be a well done tuning between kacher and grenade coil which is the very first step in replicating Ruslan's device.
MenofFather
Quote from: T-1000 on October 20, 2014, 08:02:01 PM
Well, I was listening to teamspeak session recording, not been there ;)
Also there are some opposing things about top layers winding direction as Ruslan did told to wind every single half to opposite direction in teamspeak but in
https://www.youtube.com/watch?v=iyDaVspeeNE#t=2m35 at 2:35 it is clearly seen the top half is winded on the same direction as previous. So it might to work on both cases just there is most likely question about which is better...
You probarly not good understand Ruslan. I remember, that Ruslan, newer say, that two last layers is wound in same direction like two first layers.
T-1000
Quote from: MenofFather on October 21, 2014, 03:11:00 AM
You should listen teamspeak recording again then. He clearly said there the each next half ls winded to opposite direction than previous.
But in videos the last half is on same direction than middle one.
d3x0r
Quote from: T-1000 on October 20, 2014, 03:27:27 PM
You need to lower interwinding capacitance so the Tesla secondary coil winding spacing should be at least on every second turn. Ruslan used 0.8mm diameter wire(oxygen free) as he told in latest video https://www.youtube.com/watch?v=hpYj4YT_DIs
My coil is slightly loose and I was able to wind a nylon string between the windings...
The same wire has the same frequencies of response.   Also is different with the back to back zeners on the base.
I have to put my primary almost at the end of the high voltage coil I can get it to almost near 1Mhz...
Can you please translate what 'oxygen free' wire means? :)  insulated? varnished?  really a type of annealment on the copper of the wire?
T-1000
Quote from: d3x0r on October 21, 2014, 05:27:42 AM
Please see http://en.wikipedia.org/wiki/Oxygen-free_copper for last  question.
Also the Tesla coil wire length is quite short for 1/3rd of full wavelength of grenade coil (its wire length multiplied by 4 for full wavelength)...
