0 Members and 284 Guests are viewing this topic.
Enjoykin
Who will design Phase Locked Loop for Ruslan Device - make it on pcb and give it Ruslan ??
Complete timing diagram is above. It is time for gift Ruslan !!  :)
magpwr
Quote from: Enjoykin on October 24, 2014, 11:43:06 AM
Главная причина  СЭ есть Наносека !!
How to convert extremely high potentioal into extremely high current impulse ??
It's easy when Great Nikola Tesla did and enjoykin take thought for you.
This is a Primary well hidden secret of Tesla Magnifying Transformer and secret of all OU devices based on Tesla Techology. This technology is old 100 years but is 10 000 years advanced from current technologuy. TT open way at Universe. Will it be ??? ?
hi Enjoykin,
Finally you spoken something which i didn't see before.
May i ask you just 1 question -What is the Ferrite Rod material (Give me the ferrite material number) used in the device to obtain this effect like you shown in the graph?
It's ok if you don't have the answer. ;)
Quote from: Void on October 24, 2014, 11:40:35 AM
Don't forget the part of Akula also demonstrating some of his devices to
people at their own office in Germany. It is not my concern whether people
believe or not believe, but if people are going to post possibilities about how they think
something has been cheated, it at least has to be consistent with known facts. ;)
I personally am more concerned with the technical details and what is really going on
in these devices which we know a lot of detail about now, than speculation and belief or
non belief or whatever. :)
All the best...
Those devices demonstrated in Germany were not the big ones, were they? Just small ones, lighting a few LEDs? Let us indeed be consistent with known facts please. A few button cells installed in the case of a gutted electrolytic capacitor or concealed in the potentiometer cases would work to power those devices quite nicely, perhaps even for several days.
And the fact that they were demonstrated in Germany means that those particular devices can be demonstrated in other places than "at home". So, if they are real and Ruslan and Akula want to convince people that they are real, why do they not simply send one to YOU, or someone else credible like our host Stefan, for examination? After all... they are posting circuit diagrams and photos and everything else and the devices only have a few roubles worth of components. So they are at least pretending not to have any secrets. Why not just send along a working unit then? I would.
Let us indeed be consistent with known facts, and also let us use the good sense and reasoning ability that our creator gave to us.  Why are Akula and Ruslan still powering their homes from their utility grids, rather than using their devices?
Quote from: Void on October 24, 2014, 10:35:11 AM
Hi A.King. You would have to be very close (like right next to it) to a very powerful radio transmitting
antenna to pull any significant amount of power from the near field of the antenna. This has
already been discussed here. This does not seem very likely at all for Ruslan's device with the small coils
and with his specific circuit configuration, which we know pretty closely.
All the best...
Sorry, this is incorrect. One could easily be several hundred meters away and be able to extract hundreds of watts of power, with a good ground connection and a properly tuned circuit, which could easily be of the same size as the big units we have seen.  And certainly Ruslan's station is very powerful. So just how close is he? He might even be working in the basement of the transmitter room, for all I know. Or they both could live within a stone's throw of the antenna.  Do you know?
magpwr
Quote from: TinselKoala on October 24, 2014, 12:52:19 PM
hi Tinselkoala,
Welcome back it's been a long time and we know you have more experience on the tesla coils than any of us in this forum.
Regarding this statement which you mentioned-(Similar to what Hoppy have asked in the past around 1 month back)
Answer: Yes for Akula i did spot twice a smaller version of the Grid tie around 500watt size in the older video which now no longer exist.
The little more recent video revealed Akula is already using a Grid-Tie inverter 1000watt which is located on the wall.There is 2 of those on the wall but i can only see basic spec of one at the top.
Observe this baby within 10 second of this video which was not the highlight from Akula but spotted by me.
Now we know in Russia Solar cell is not a viable solution. :D
Grid Tie does accept a wide range of input voltage eg:11volts to 22volts as an example meant for solar cell.The 24volts gird tie run on higher voltage with around 10volts tolerance.
http://www.youtube.com/watch?v=-rALEpvBQig
Do check out this post of  Enjoykin in this same page about tesla coil and the ferrite rod which is said to produce nanosecond pulse which i find it hard to swallow since i have never seen this before and i don't if this will work if tesla coil is connected via ferrite rod in order to observe nanosecond pulse which i don't know if these pulse appear "automatically or magically" just by using ferrite rod.
