0 Members and 518 Guests are viewing this topic.
Void
Quote from: itsu on October 24, 2014, 02:38:26 PM
I got this link via a comment on my youtube channel today:
http://www.teslametamorphosis.com/p_p7_Marjanovic_TeslaWaves.html
It explains the working principle of the antenna coil around the grenade.
Regards Itsu
Thanks Itsu. That looks interesting. I'll try to read through that this weekend.
All the best...
MenofFather
Quote from: Void on October 24, 2014, 04:01:22 PM
Yes, it may not be necessary, but can't be sure without knowing exactly
why Ruslan chose to do it that way. Probably you just need to get your tesla coil
running on your desired operating frequency (eg. 1.6MHz to 2 MHz). Winding opposite
windings on the secondary may help for tuning without removing turns. I'll try it this weekend
if I get the chance. :)
All the best...
Ok I bealive, that oposite windings is not nessary. Ruslan humanor not human? If he human, then it can make not nessary windings-mistake. Right?
Hoppy
Quote from: MenofFather on October 24, 2014, 03:07:55 PM
I shore, that restangular wire is not nessary, you can wound only 0.8 mm wire and ajust kacher with antena to 1.6 megaherc or something close to it. :)
Do you mean a second layer of 0.8mm wire (instead of the rectangular wire) wound anti phase (opposite direction) to the first layer, or that a second layer of 0.8mm wire is not necessary?
Void
Quote from: MenofFather on October 24, 2014, 04:08:24 PM
Hi MenofFather. Not following you. :) I already mentioned that I agree it may not be necessary,
but may be just one way Ruslan was trying to fine tune the frequency of the tesla coil. It is anyone's guess what Ruslan's
intention was in doing that, unless Ruslan explained this somewhere.
All the best...
Jeg
Hey guys
I made a katcher driver, and fired my well balanced system for first time. By well balanced I mean it is tuned as to have a nice and clean sine wave peak at 2Mhz. It is a clean sinus without ripple even when I drive the line through square pulses. That means that it is tuned exactly on a frequency which is related to the exact wavelength. So far so good.
My katcher is tuned at 2Mhz with a coax cable as antenna shortcuted at the end as Dally's one. Katcher puts out not more than 2-3Kv. My bulbs didn't light more while firing. By measuring the voltage inside the grenade line while firing, I see a 2Mhz 20V peak to peak which comes from antenna. Almost nothing..
Two things. Either katcher has a very low output, or needs synchronization. What is your opinion? I saw Ruslan's katcher, it doesn't seem stronger than mine. Katcher's signal is also a nice and clean unipolar pulse.
