0 Members and 347 Guests are viewing this topic.
Hoppy
Enjoykin,
Please explain: You posted a shot of Ruslan's coil assembly (see below) showing an impedance transformer. As you describe this as a transformer, am I right in assuming that the rectangular strip is not connected to the end of the multi-turn 0.8mm Kacher secondary coil? It does not make sense to me that the Kacher voltage should be transformed down before being connected to the antenna. Also what is the specification for this tape?
Enjoykin
For me it has a sense !!
My analog are two water pipes - one very small diametr and one big diameter.  Only way to connect both is join them 3rd pipe which will tranform smaller on bigger diametr. I think there are several turns - piece of rectangular copper strip 4..5 mm width, connected one end at 0.8mm wire and other at bifilar choke.
1st picture is Akula device. Strip is on secondary beginning - 2nd Ruslan device - on the end of Katscher secondary. I think Ruslan schematic is valid and there does not exist any hidden conductors.
Simple this should be tested with Katcher in two variants. a) Coper strip is same direction as secondary b) opposite direction. There shoud be about 2..6 turns of strip. Bifilar choke need be wounded as Akula and Ruslan choke.
Reg.
Hoppy
Quote from: Enjoykin on October 25, 2014, 05:48:26 AM
Reg.
Thanks for your thoughts on this. It could be an important part of the build but why call it a transformer, as this implies its working by induction, which it clearly is not if its connected at both ends between Karcher secondary and choke?
Jeg
Menof I already tried to drive the inductor with high freq. Nothing happens
Itsu I have changed a couple of antennas but nothing. The real challenge for me at this point, is to pass radiant into the circuits. And just as with simple radiation over grenade is a dead end at least at the voltages that we are talking about. There has to be a secret over here. I am between galvanically entering radiant inside the grenade line, and/or the case that somewhere in the grenade is a hidden something. Perhaps a layer of tin foil between the coils to form a some short of capacitor? I don't know. But next days is what I am going to test.
By the way, at the picture you can see my katcher choke which cuts all the HV return to the psu. Two coils winded same direction. 4 meters cable 0.6mm per side, folded in the middle and starting winding from the folded middle. 55uH per side. It just rocks. You can even touch the return with your tongue. I didn't do it of course but I want to mention that HV return problem disappeared.  :)
Jeg
The first waveform is at the cathode of the diodes while system is working without katcher. 33.3Khz 400Volts lighting 200 watts of bulbs the same time.
Second waveform is the same peaks but zoomed, while katcher is on fire! See the 2Mhz imposition from katcher antenna. The ripple is at about 15-20 volts pk-pk. System can not sense them because are very low compares to 400V.
