0 Members and 581 Guests are viewing this topic.
Hoppy
Quote from: Jeg on October 25, 2014, 08:52:17 AM
There has to be a secret over here. I am between galvanically entering radiant inside the grenade line, and/or the case that somewhere in the grenade is a hidden something. Perhaps a layer of tin foil between the coils to form a some short of capacitor? I don't know. But next days is what I am going to test.
Its interesting that Kapanadze uses stripped coax (plenty of capacitance here!) for his grenade coil and I think he has his HV coil inside the grenade tube.
AlienGrey
We are starting to get a bit confused here, If we have 37.5 meters in our Grenade coil we have a wave length of about 7.95 megahertz, ok so far to here, now we are according to T1000 we are using 1/4 wave length so that would be about 2.0 Megahertz.  Now at the other end we have a coil that's 1/3 wave length as Akula is dividing by 3 in his logic so that is 7.95 / 4 / 3  in my book that's the same as 37.5 / 3 = 12.5 T, so where does 4.8 and 1.6 fit in to this as you would need a different frequency - wavelength.  and not all wave lengths would tune, from what i understand, now if it works i don't know yet, but not lets drift off too much yet! and don't alter the turns or wave length, ok, (  did any one measure the length of the cable on the grenade shape coil ?)  good luck to you all.
itsu
Menof I already tried to drive the inductor with high freq. Nothing happens
Itsu I have changed a couple of antennas but nothing. The real challenge for me at this point, is to pass radiant into the circuits. And just as with simple radiation over grenade is a dead end at least at the voltages that we are talking about. There has to be a secret over here. I am between galvanically entering radiant inside the grenade line, and/or the case that somewhere in the grenade is a hidden something. Perhaps a layer of tin foil between the coils to form a some short of capacitor? I don't know. But next days is what I am going to test.
By the way, at the picture you can see my katcher choke which cuts all the HV return to the psu. Two coils winded same direction. 4 meters cable 0.6mm per side, folded in the middle and starting winding from the folded middle. 55uH per side. It just rocks. You can even touch the return with your tongue. I didn't do it of course but I want to mention that HV return problem disappeared.  :)
Jeg,
At 09:45 in this video:  https://www.youtube.com/watch?v=fp3sed_eli0  you can hear Akula speak about capacitor (condensator)
and pointing to the grenade coil, so there must be some capacitance at play in there.
Perhaps the secret is in the link i provided yesterday explaining the third coil.
I build a similar Kacher driver with a common mode choke at the input, but i have to bypass the ground/minus from this choke else the
kacher won't oscillate, i wonder why that is?
But at 25v, i can pull 1cm of streamer fom both the end of the antenna coil as the end of the kacher lead and/or the ferrite of the inbetween choke.
Frequency is now at 1.5MHz, but i understand that my Kacher is wrongly wound as it is the same direction as the antenna.
Rewinding is ongoing......
Regards tsu
itsu
Quote from: Jeg on October 25, 2014, 09:18:35 AM
The first waveform is at the cathode of the diodes while system is working without katcher. 33.3Khz 400Volts lighting 200 watts of bulbs the same time.
Second waveform is the same peaks but zoomed, while katcher is on fire! See the 2Mhz imposition from katcher antenna. The ripple is at about 15-20 volts pk-pk. System can not sense them because are very low compares to 400V.
So that first waveform would be taken at the 28 turn secondary of the yoke?  Thats a lot.
Do you also have a negative voltage (300V i guess) compared to ground on your bulbs then?
Regards Itsu
itsu
Quote from: Hoppy on October 25, 2014, 10:19:41 AM
Does stripped coax still has that "plenty of capacitance"?
Regards Itsu
