0 Members and 581 Guests are viewing this topic.
Jeg
Jeg
Quote from: Enjoykin on October 25, 2014, 01:54:30 PM
Jeg3 variant - This was checked and made  by Akula with Tesla Transformers and he got 1.5kWatts OU.
Your Grenade is in fact HV capacitor. I thnk you need synchronization to get OU effect. Be sure to make bifilar choke between Katcher and antenna exactly like Akula and Ruslan did.
And try to record your ground response - because push-pull must work at some harmonic of Ground Frequency and Katcher need to pump Grenade exactly on same frequency. Connected on bifilar-choke and antenna.
If you did tests - tell me free resonant frequency of your Katcher at secondary. And frequency with connected choke and antenna !!
Enjoikin, at this above drawing of akula, is that an aluminum wrapped on the core connected to ground through a coil?
About 3.60Mhz free oscillation, 1.65Mhz with antenna, and then when everything in place I started unwinding and measure until 2Mhz
AlienGrey
Enjoykin Hello, can you please explain how the Tesla magnetic diodes work please, many thank ;)
Enjoykin
Very interesting Jeg. Did you checked that variant ?? On back side magnetis are opposite.
Btw that Magnet Configuration is discovery of famous physicist  Genady V.Nikolaev - SIBIRIAN COLIA. Name had gave his best friend Stefan Marinov.
SIBIRIAN COLIA is source of Scalar Magnetic Field. H*= -div A. A is Vector potential. Toroidal configuation is ideal source of Scalar field because Vector (transverse filed) is exactly "locked-in" toroid while Scalar field is out. This is from Nikolaev theory.
Any idea how to detect scalar magnetic filed ? For example in Ruslan device or SIBIRIAN COLIA ??
Jeg
Quote from: Enjoykin on October 25, 2014, 03:14:30 PM
http://www.cheniere.org/books/ferdelance/s33.htm
See also barkhausen effect
Is there any idea if a capacitor in series with the ground cable will make the line vibrate where we want?
