0 Members and 170 Guests are viewing this topic.
itsu
New Kacher wound,  now opposing the antenna direction with choke inbetween.
Frequency is 1.320MHz, so need to get it up as the grenade response shows its not in resonance with it.
Video here:  https://www.youtube.com/watch?v=YkKoY0v_yH0&feature=youtu.be
Regards itsu
magpwr
hi everyone,
I have discovered something of importance which is related to Ruslan device as seen in the recent video.
In video you can see Ruslan is using 0.47uf x 2 + "Smaller capacitor which i put it at 0.22uf" + "Another smaller capacitor unknown value which i insert as 0.033uf"
So we have estimate total capacitance value of =1.193uf or 1.2uf (Nearest value) possibly used in Ruslan device.
Since i do not know the micro Henry value of the 25 turns x 2 winding.I merely insert base on value obtained from my device from the 25 turns x 2 windings which is 124.5uH
In order to find out the frequency which is likely being used for Ruslan device.I use a suitable web site to derive the frequency in khz.
I just apply L/C value 1.2uf for capacitance and Inductance at 124.5uH as attached.
The frequency i got was 13khz.This is definitely half wave resonance of the actual frequency at 26khz which is the output of 3 turns yoke core.
By applying 26khz into the harmonics calculator and take a look at 60th Harmonics of 26khz which will be 1.56Mhz.
http://www.pronine.ca/lcf.htm
This 1.56Mhz would be the estimate frequency for Ruslan tesla coil with Antenna would be resonating.
If you are connecting 3 turns of Yoke core to 25 turns please apply 1/2 wave formula as mentioned above in order to derive the "suitable capacitor bank value" to connect to device 25x2 winding.
"Isn't this fun." :D :D :D
Simple way to solve this is to start assembling high voltage capacitor in parallel to form around 1uf.Then add smaller high voltage capacitor value from there.
:D
"This figures is only useful for those whom are interested in harmonics."
"The most important thing for me is to get all the frequency alignment right before even thinking of connecting to a bulb at the last stage"
Base on Tesla note we need to figure out on how to lower the EM Wave(Electromagnetic wave or radiated wave is going outwards from tesla coil) and convert this into inductive power.
I know by using a simple av plug 1n4148 x 2 connected to led can be used to measure how well the tesla coil is radiating from a small distance.
I am not sure if we need to measure for inductive power from tesla coil merely by connecting led to 1mH/10mH coil and place nearby or observe for Amps reading at the single earth cable for tuning purpose.
The the only thing which is standing in my way before i actually complete the outer coil winding is the nanosecond pulse on where it needs to be injected."Just remember the word knife from Tesla"
John.K1
Hallo guys.
I also started to build the Ruslans's device. I have listen his almost 2 hours skype interview with other guys like "free energy LT" etc.  Couple interesting notes: (1) Kapanadze builded his device without any electronic instruments like scopes an analysators. He had just a volt and amp metter. He as a architect just measured the wires on cm. ,  (2)  build the granade coil as shown in his video and note the length to calculate its frequency (1/4 wave) IT IS NOT ADVENTAGE  to have morre wire here than around 40m. (3) Tune Tesla to the granade coil. Do not forget Tesla coil has still its own frequency,no matter how fast u puls it. -It looks to me he used 1/4 wave of his 2Mhz (grenade coil), (3) Ruslan didn't have success with nanosec impulses. (4)The capacitor on the output is very important what is made from and how big is as it collects what it recievs from the grenade and resonates (5) grounding change a resonant frequenci bit. Some more wire required to tesla. (6) The lenth of grounding cable mentioned (aroun 20 m) .
   My russian is poor ( so my English)   I got a problem to understund what he said aboutbut his tv choke. Possibly there is 26 turnes of shunted wire  + 2*12 turns same way + 3 turns.?      That's all folks  :) Easy as that ;)
magpwr
hi everyone,
Base on my earlier posting in the day.
I have assembled a 1.06uf LOW ESR capacitor ( Polypropylene)which is used in induction heating.The capacitor voltage rating is 1200VDC and the A/C is 800Volts little better than than the WIMA 0.47uf MKP10 at 2000VDC at 700Volts A/C.Since we are working with high voltage A/C here. :)
I have attached all the photo base on experiment done in the afternoon without Tesla coil operating yet.As you can see i am lacking a proper stand for pvc pipe.But this will be sorted out later on.
In order to see nearly "100volts peak to peak using 20watt of power as shown in my attached digital watt meter"  across the "1.06uf capacitor bank" which is connected in series to the 3 turns(6mm sq) on large nano-crystalline toroid to the 25 x 2 turns winding.
I have adjust the signal generator to 871khz sine-wave.This is fed to my 1/60 frequency divider circuit and it's driving the IGBT at 18.5volts(Using voltage boost circuit at both IGBT driver)
The output frequency is 871khz/60= 14.516khz as shown in my attachment with 100vpp sine-wave across 1uf capacitor.
Now base on my earlier posting in the day.I have mentioned that we should use 1/2 wave resonance and should never run this exactly at resonance as what we have been taught.
Put it simply without applying any further modification to the example 1.06uf capacitor bank.
We should now take note the resonance frequency of the tesla coil which we need to run
.This will be 871khz x 2 =1742khz or 1.742Mhz (Frequency which my tesla coil would need to resonate after connecting all the antenna and etc).
Since my tesla is running at 1.742Mhz  the output of the frequency divider/driver circuit would run at 14.516khz x 2 =29.032khz .
Now this is the interesting part just by doing this is not going to produce interesting output.We need to inject nano second pulse somewhere in the device which will "cut waveform at the half"(This word was mentioned by Tesla).The nano second pulse need to be injected at the"positive" peak of the waveform.
If my theory is right then tesla coil would not be radiating EM wave once nano second pulse is applied at peak of lower frequency waveform eg:27khz..37khz.It will start driving the 25 turns coil and the device.
At this point of my experiment without tesla coil in operation there seems to be small increase in brightness upon connecting wire from top of multi layer winding with bulb to metal pipe(Earth for my case) at the cost of little higher current drawn as shown at 1.64Amp(Watt meter).
The bulb used in experiment is mere 60watts which was not the point.
Jeg
Meow, your point of looking things is always welcomed! :) I like this theory of substituting cap with pair of coils. Do you know any Tesla patent that describes exactly this behavior of a couple of coils under this high voltage pressure? Any else's theory or idea which utilizes two coils forming a capacitor? As far as I know is that when signal crosses zero, coil behaves as a capacitor plate. But I can't see any reference or similar tests and experiments..
Welcome aboard John, and thanks for informing us about ruslan's way of calculations. Good luck on your Ruslan journey.
Nice work itsu, very elegant and careful. I see that even you transmit in low frequency, your output is weak. In my 3055 circuit I consume 1A and I have lower bias resistances like 1000 and 50 Ohm to raise the voltage output. But again I am not very happy. I can't trap the right amounts of the transmitted energy. I obviously miss something.
Mag, nice work and skills. It was time to make your grenade. Good luck with your build
Void, nice to see you building this at last. We need your parallel input and observation to all of this.
Good day people
