0 Members and 745 Guests are viewing this topic.
John.K1
Guys , what wonders me is why Ruslan is using such a short Tesla coil. If the principle is based on the ionize air and scalar wave, I believe the surface( length) of coil matter matter. I started to build  that device too and got till now as far an on the picture. What I do is make a Tesla coil half wave. It is giving me around 30cm of 0.3mm wire.
MenofFather
Quote from: John.K1 on October 26, 2014, 06:06:53 AM
Ruslan may himself not understand that is principle. You think he is not human and can not made mistake?
Short coil is needed to get hight frenquency of kacher (1.6 megaherc). With long coil you not get that frenquency.
John.K1
Menofather. Why can't you get the same frequency  with longer coil ?? :) full wave, 1/2, 1/4 or multiplies of resonant frequency still can vibrate on the same given frequency :) Let's say his tuning frequency was 3.3 MHz (that's what he showed in the movie)  , He use 0.8mm wire. His tube is D50.  The length of wire to tune to get that natural frequency would be 300/3.3MHz  = ±91 m.  One turn takes 3.1415*50=0.157m. From that 91m/0.157m=579.62 turns. He Use plastic insulated wire - it means the pitch would be like 1.6mm.  So, in his case full wave resonator should be long around as 579.62*1.6= 927mm. He shows just around 11-12 cm. It wouldn't be even 1/4 wave. I  am confused from that. In any case I wound 1/2 wave resonator with magnet wire and I separate them with sawing thread and the varnish on top.
Thanks.
Enjoykin
Hoppy
Quote from: John.K1 on October 26, 2014, 03:11:05 AM
Hallo guys.
I also started to build the Ruslans's device. I have listen his almost 2 hours skype interview with other guys like "free energy LT" etc.  Couple interesting notes: (1) Kapanadze builded his device without any electronic instruments like scopes an analysators. He had just a volt and amp metter. He as a architect just measured the wires on cm. ,  (2)  build the granade coil as shown in his video and note the length to calculate its frequency (1/4 wave) IT IS NOT ADVENTAGE  to have morre wire here than around 40m. (3) Tune Tesla to the granade coil. Do not forget Tesla coil has still its own frequency,no matter how fast u puls it. -It looks to me he used 1/4 wave of his 2Mhz (grenade coil), (3) Ruslan didn't have success with nanosec impulses. (4)The capacitor on the output is very important what is made from and how big is as it collects what it recievs from the grenade and resonates (5) grounding change a resonant frequenci bit. Some more wire required to tesla. (6) The lenth of grounding cable mentioned (aroun 20 m) .
   My russian is poor ( so my English)   I got a problem to understund what he said aboutbut his tv choke. Possibly there is 26 turnes of shunted wire  + 2*12 turns same way + 3 turns.?      That's all folks  :) Easy as that ;)
Hi John.K1,
Welcome to the Ruslan replication team.
You make a good point about Kapanadze using just very basic test equipment. Ruslan has demonstrated that its not even necessary to have the nano-pulser and his devices are . Between us, hopefully we can eventually get to a stage where we can confirm whether the Ruslan setup is genuine.
