0 Members and 575 Guests are viewing this topic.
Void
Quote from: Hoppy on October 26, 2014, 04:59:09 PM
Thanks Enjoykin. Do you have the spec on the diodes?
Hi Hoppy. The DL112-16 appears to be a 1500V (or 1600V?) 16A avalanche power diode.
http://astrael.ru/index/leftmenu/18/eng
Belkin also listed testing this diode in his PDF on nanopulser circuits using DSRD's.
Belkin listed it as rated at 1600V.
http://www.overunityresearch.com/index.php?action=dlattach;topic=1556.0;attach=8656
(See Table 2 in the above PDF for Belkin's listed specs for this diode.)
All the best...
Void
Quote from: John.K1 on October 26, 2014, 12:19:21 PM
Just repeat what Ruslan said - " Forget about LC resonance here. Only LC resonant here is the Choke transformer. The length of wire is is the length of the wave. Do not run scopes or SG here as you will get ..."one of Russian words here :)
Now me:  we can or do not need to agree here. Personally it sounds a strange to me too. For example my "grenade" coil shows on scope max peak at 680 KHz  With respect to my wire length it should be 1.8MHz- but - Ruslan is the one who has a functional device and I can't to complain to him, so I forgot about that 680KHz and will tune Tesla coil to 1.8 MHz.
My point of view is that coil has its wave length on which it resonates no matter what. And no matter how strong or in what rhythm you will " beat it" it will still resonate in its natural  frequency.  yes- considering tank circuits you are right and the mutual capacitance, inductance and other factors play the role here . But I am not sure if this is the case here with respect to what Ruslan said.
Hi John.K1. Welcome to the forum. Those statements by Ruslan about basing frequencies on wire lengths is
what I am experimenting with. What is the length of wire in your grenade coil? I am wondering where you are
getting 1.8 MHz from. Did Ruslan explain any specific details about how he determines what frequency to tune his tesla coil to,
based on the wire length in the grenade coil? In Ruslan's latest videos he apparently mentioned he tuned his tesla coil
to about 1.6 MHz. Any idea what length of wire he used in his grenade coil to end up with 1.6 MHz for the tesla coil?
1.6MHz = 187.5m wavelength
187.5 /4 = 46.875m (quarter wavelength)
Is his grenade coil wire that long? If not, then the theory that the tesla coil frequency
is based on the grenade coil wire length would appear to not be correct, or there is more to
it than just that.
All the best...
AlienGrey
Hi John K1 and Void,
i think the point is does 1.8 decide out t to 8 Hz ? 1.8mhz is 1800'000 / 8 = 225000. so yes it does
I have a Tesla coil and if i fire it up i get a huge HV pulse but on my scope i get noise like grass growing along the trace, but if i alter the frequency and turn up the wick, i see one echo larger than the rest, now if i tune that to my huge pulse all the noise goes and the huge pulse cleans up. If i then look at the frequency I find it will divide exactly by 8hz. Now before you ask me i haven't tried to mach the Primary to the secondary or test the ratio but its not fully matched, I would assume that would be important! Ive also tried this with a few older and smaller ones and it's the same, what we are doing as far as i can see is we are bouncing energy into a coil, and as soon as it gets to the end of the wave we cut it off and then wait for it to come back and grab the return energy, as far as i can understand. If it helps all well and good.
John.K1
Hi Void and guys.
Ruslans grenade coil has 37.5 m . My has 39.9 m. It is 1/4 wave antena and Tesla has to be tune to it.
Some more word from Ruslan  ;)  :
topruslan пишет:
Попробуйте зарядить конденсаторы через диодный мост от теслы. Всё поймёте ! Радиант - заряжает их мгновенно при этом не затрачивая времени
Cheers.
MenofFather
Quote from: Void on October 26, 2014, 07:55:29 PM
it than just that.
All the best...
In smaler power divice, were he write that multilayer coil is 37,5 meters. Kacher frenquency he say is 1,5-1,6 megaherc.
"Any idea what length of wire he used in his grenade coil to end up with 1.6 MHz for the tesla coil?  "[/size]
He use here 37,5 meters.[/size]
