0 Members and 91 Guests are viewing this topic.
a.king21
I asked Kapanadze specifically about the ground issue. (In retrospect I wish I had specified a non-earth device.)
Anyhow, we have what we have;  Kapanadze told me the earth ground  could be replaced by a circuit. When I pressed him further he said it could be replaced by the negative of a car battery. The team in Tbilisi did disconnect the earth ground for a few minutes and the device continued to function.
This is of course pure Tesla tech, as I have read in the past.
My personal view is Tesla's word that the earth acts as a perfect conductor. I have personally transmitted power through the earth with no losses I could measure. My earth rods are ten feet apart.
I am following this thread closely of course.
I am looking into using the Slayer circuit as a ground transmitter and see where it goes.
Magluvin
Quote from: a.king21 on October 29, 2014, 10:01:14 PM
Its interesting that the neg terminal of a car battery could be a substitute for earth ground.
Not sure what that means for energy transmission from transmitter to receiver, being there is no longer a connection via earth ground between the 2.
So the neg terminal of the battery must be acting a a reservoir of excess electrons that can be used by the circuit without having to force only the electrons that are in the circuit already around in a loop of circuitry alone.  So I wonder. If it is so, are the excess electrons at the neg side of the car battery available to a circuit without a positive connection to the battery by the circuit? Can they be taken from the battery easily and replaced as easily, or even forced to take on more electrons, by a circuit that does such?  Or is there say a spring function where it takes more and more pressure from the circuit to pull more electrons from the neg side of the batt, or packing the neg side with more electrons than the batt started with?
Possibly we might need high voltage to push and pull enough electrons from the neg terminal of the batt in order for it to matter at all. Like a AV plug, it appears to push electrons into one side of the cap during one phase, and pulling from the other plate of the cap during the other phase. So only one plate of the cap sees any action during one phase and the other plate in the other phase.
I remember when i was about 10yrs old, I had a couple electronics project kits. When making the crystal radio using ground, I had an idea that since the earth ground allowed the ability for ac current to flow in the circuit, i tried just a long piece of copper pipe as a ground connection. The pipe didnt have to be connected to anything other than the radio ground. And I got a signal. Not as great as the earth ground, but it did work and allowed the radio to be portable without being tied to the ground. Of course the isolated pipe didnt have an abundance of extra electrons as the neg terminal of the battery, but it did give and take from the radio circuit in order for it to work.
Now i wonder if that crystal radio would have played better by just grounding it to a neg terminal of a car battery instead of the pipe. Or play near as good as an earth ground in comparison to the pipe alone.
So is there an advantage to a circuit of a particular type to have more electrons in the circuit(or less as the circuit brings in or pushes out electrons at any particular time) than just the number of electrons in the circuit alone? If there is, what is it? ;D
Mags
URFA
Hi Enjoykin.
I have some experiments and I think I have achieved some effect. It is OU effect or not I don't know because I haven't oscillascope.
This effect is possible with Kacher.Without Kacher not effect.(have to be antenna).
There are some problems with the operation of the device . I know what the problem. I am working on it. I'm trying to fix problems.
After correcting these problems, I will share with you a new video.
I now Uploading Videos on YouTube. I'll give you a link when it finishes loading.
Regards Ibrahim
John.K1
Quote from: John.K1 on October 29, 2014, 06:34:24 PM
Guys,
Maybe it was here already, but never mind. Just listening Ruslan's Skype conversation and with my poor Russian I catched this information:
The frequency of small induction coil ( TV choke) must not oversize 10th harmonic. In his case 20KHz . 20KHz has to be signal generator. Than you will get sharp edges."
Cheers
Sorry Guys, I was lost in translation. Ruslan said 100th harmonics.  = 20KHz
