0 Members and 139 Guests are viewing this topic.
URFA
Quote from: Void on October 30, 2014, 11:01:51 AM
Hi Urfa. With no detailed explanation of what you are doing, it would be pretty hard for
anyone to be able to properly assess what is happening in your videos. Too many unknowns.
In the very least details on power consumption of kacher and push pull driver circuits are needed,
plus wattage of the light bulbs.
All the best...
Hi Void.
In fact you know everything about my setup. I used Ruslan's schematic. He drew in his video. His scheme was published by Enjoykin and GeoFusion.It was posted a few pages ago in this forum.
In my setup.
Power consumption of kacher: 24 V  1.8-2 A
Power consumption of push pull driver circuits: Without kacher 24V 2A but I measured when kacher runing Its power consumption is growing about 24V 7-8 A.
Power consumption of kacher and push pull driver totally 9-10A(24V)
I have 4x40w and 1x100w  220v light bulbs. Totaly 260w and When kacher run they are fully brightness.
My setup not OU.I only share this video with you to show the effect of Kacher. I'm still working on this system like you.
Note: I can not fully express myself Because of my bad english :'(
All the best..
URFA
Quote from: MenofFather on October 30, 2014, 11:10:27 AM
Then you addading kacher lamps shine brighter?
Hi MenofFather.
Yes. When I adding kacher lamp brightness increases.
URFA
Quote from: T-1000 on October 30, 2014, 03:15:05 PM
Hi,
You need to get disconnected from the  mains grid first. Please use disconnected computer UPS or battery for power supply. With mains connected there is no effect as the system is supposed to reach ground over grenade coil windings only...
Cheers!
Hi T-1000
I want to reduce the power consumption of the my device a little more. I know my device's power consumption is high for OU. I think when I disconnect main grid this setup it will not work. After some more experiments I'll do what you say  ;)
And Ruslan says about my setup on Realstrannik forum:
Ruslan Says:
На видео есть реальные шансы системе заработать. Но очевидно не правильно сделан съём энергии. Потому нет самозапита. КПД виден и чувак близок к успеху на 90%
google translate:
In the video, there is a real chance to earn system. But obviously not done correctly will eat energy. Because no samozapita. Efficiency and seen dude close to success by 90%
All
magpwr
Quote from: URFA on October 31, 2014, 04:06:58 AM
Hi T-1000
Ruslan Says:
google translate:
All
hi URFA,
I was impressed by your video but at quick glance i have also spotted 2 mistakes.
Please avoid using full-bridge rectifier module at cost although it looks like most easy solution.I have already discussed about this previously that this module is only designed for mains frequency 50/60hz.
The catch is if you try to try at higher frequency in khz range this module won't able to deliver the same Amps as it was rated for.Do check all full bridge recitifer datasheet and it is very rare to spot a module
which can support higher frequency.
Please assemble using diodes like UF5408 3Amp x 2 in parallel for each side to form full-bridge rectifier as an example.
Another previous discussion the full bridge diodes or module inside the 24volts power supply may need to be altered to cater for the high frequency.
Thanks for the video.Keep it up.
skywalker66
@  magpwr
In his video seems that full bridge is not use, I meant it is just connected at input side through an series capacitor (single brown one), but the rectified output is left free. Just another capacitor across output for filtering purpose, but not loaded, at least like I see from video.
