0 Members and 720 Guests are viewing this topic.
skywalker66
@ URFA
Hi !
What is hissing in your setup when you move your hand near the cooper antenna ?  Is main yoke, is 24V power source, or something else?
You get interesting effect in deed, seems you are close, but from what I see you may have mess some connections at output side than Ruslan's hand schematic from video, from where probably your large consumption of current. God luck !
itsu
Quote from: John.K1 on October 30, 2014, 07:16:11 PM
Guys, some question here. On the picture below is my basic structure of the device.  I have it a bit different than Ruslan.or my Tesla coil  I used 0.3 wire separated with the sawing threat and varnished. If the principle is based on the Ionization of the air I think the surface matter. My Tesla is long 30 cm ( Ruslan has around10 cm) and it is a half wave of 1.87 MHz- which is my bifilar"grenade" coil. My question is - does it matter in what direction is wound primary of the Tesla??  I believe not, just want to make sure. May be somebody has experience already with that.  My next question is that opposite  wound coil right behind the Tesla coil. If I have my all Tesla already wound in that direction do I have to put that extra wire there and in what direction if my Tesla is wound in opposite to Ruslans?
Thanks,
Hi John.K1,
nice build, but looking at your Kacher, it seems to me it must be working in "dual quarter wave" mode  :)
So you probably have 1 quarter wave going to the right side from the center primary coil, and another quarter wave to the left.
No idea what this has for influence on the whole, but it could be it cancels out something you need.
I would suggest to move the primary to the left (bottom) of the Kacher secondary, and probably it will start working in
single quarter wave mode, meaning half of your frequency (935KHz) so you might need to remove some secondary wiring to get back to 1.87MHz
I understand that the Kacher secondary needs to be wound the same direction as the Grenade coil layers 1 and 2.
For what its worth,   regards Itsu
corry
Quote from: URFA on October 31, 2014, 04:06:58 AM
Ruslan Says:
.... Because no samozapita....
But, what does this mean?
MenofFather
Quote from: corry on October 31, 2014, 06:32:18 AM
Because no selfrunning. Samozapit is selfrunning.
Void
Quote from: URFA on October 31, 2014, 03:45:44 AM
Hi Void.
In fact you know everything about my setup. I used Ruslan's schematic. He drew in his video. His scheme was published by Enjoykin and GeoFusion.It was posted a few pages ago in this forum.
In my setup.
Power consumption of kacher: 24 V  1.8-2 A
Power consumption of push pull driver circuits: Without kacher 24V 2A but I measured when kacher runing Its power consumption is growing about 24V 7-8 A.
Power consumption of kacher and push pull driver totally 9-10A(24V)
I have 4x40w and 1x100w  220v light bulbs. Totaly 260w and When kacher run they are fully brightness.
My setup not OU.I only share this video with you to show the effect of Kacher. I'm still working on this system like you.
Note: I can not fully express myself Because of my bad english :'(
All the best..
Hi Urfa. Thanks for the details on your setup. Your English is fine.
Keep at the experiments. You are doing well. :)
All the best...
