0 Members and 562 Guests are viewing this topic.
Hoppy
Quote from: MenofFather on November 03, 2014, 01:34:28 PM
Yes. Not all toroids making pulses on secondary.
Thanks for your confirmation Mag.
I have found that a 0.22uF cap tunes my inductor to resonance giving 160Vpp at the grenade frequency of 33.3KHz. The inductor will oscillate at the grenade frequency as set by the PWM. Now I need to know the function of the inductor.
Void
Quote from: NickZ on November 03, 2014, 09:37:29 AM
I just measured my 12,12 turn coil for my grenade inductor coil (12v set up), and it is was 16 foot, 5 inches long. I don't have a metric tape measure, I just provide this in measurement in feet, as a comparison. So, if anyone is interested they can just convert it to meters.
That works out to a wire length of about 5 meters Nick.
All the best...
Void
Quote from: Hoppy on November 03, 2014, 02:04:44 PM
Indeed, as everyone does. :)
All the best...
GeoFusion
Hi Guyz,
Quote from: NickZ on November 02, 2014, 02:40:14 PM
  Geo:
   I watched the video that you posted the link to. What it shows is that the Tesla Bifilar way to wind the 12, 12, or the 25, 25 turn inductor coil on the air core can be made to work, either way.
  The first Akula device just pulsed the yoke's 3 turn coil through the capacitor to  the inductor coil which was wound on top the big air core coil. Similar to the video you posted. This was without the 28 turn air coil, as is used now. But, this way if used by itself, is not a self runner, only an inverter crt, if there is no feed back path.
  The first Akula video used a feed back coil on top of the big air coil, connected to the full bridge rectifier, and filter cap, and then back to the power supply unit, to supply the self running input. Without this is it would also just be another an inverter crt.
Nick,
Yes, the yoke in first akula device is being pulsed so that the 3wind coil and cap could generate high voltage (kilovots or less) and be in resonance with the inductor for output on air coils. This circuit can drive a Tesla coil also, if you see it as a pulse generator without SparkGap.
The first layer of the air coil functions as a tesla coil but then have to step it down coiling a second layer on it and not the forget the ground
that increases the output and keeps the system running efficiently.
we have seen various of the schematics already on the net.
In any case, in the video you see Meno showing the system work as how its being posted with schematic,
true he ain't feeding the system back (yet) , but showing an  tremendous output with the grenade coil  , Kacher and ground, but lets see how he manages if he still up for posting more vids. It might seem now as a inverter but not a conventional one but this is the way to go,
remember it's using radiant energy using ground.
sharing the info and for our progress on these tech.
Hoppy, magpwr,
No problem guyz, Here for the help and for progression of replication.
But keep it up, as we see in Meno's recent vid, the Inductor pulses are producing energy in the grenade with the help of ground and
kacher's ground connected to it too, Without the 28 winds of yoke connected.
This show's that this Inductor can be used to excite a Tesla coil, Was drawn by akula some time ago.
Hoppy, now that you have changed to a  0.22uf cap and showing 160Vpp, see if you can light up that 10W bulb. see if there is change.
Meno,
What a surprise to hear it was you in that recent new video with the schematic and yes the inductor should be Tesla Bifilar wound correct.
   To all who are experimenting.
When reaching about 160- 180 V with grenade outputs, try to connect PSU/ stepdown Trafo and see to make it work as what we all are waiting for after tuning and all.
Only thing matters now is to achieve great output from system, maintain High frequency for lower input.
Cheerz
itsu
Quote from: skywalker66 on November 03, 2014, 01:29:52 AM
Hi Itsu!
After winding inductor coil, now you have 2 coils with 2 different resonant frequency, therefore the response at signal generator stimulation will be a combination of the two frequencies. A very nasty business...
For finding new frequency, you may try this:
1. Connect a 0.47uf across your inductor, and put to ground the upper leg of inductor. This will disable the influence of free oscillating of inductor on resonant freq. of grenade.
2. Put your test coil from FG across 6-th layer of your grenade.
3. Put oscilloscope ground to upper leg of grenade, and between scope probe and lower leg put 100k resistor, scope probe set on 10x - for keeping as minimum as possible influence of probe's capacity on resonant freq. of grenade
4. Sweep FG for max. amplitude on oscilloscope. You will find new freq. somewhere between 1.6 - 1.8 MHz. That will be the freq for kacher shutting of.
I hope this will help.
PS: This is just a theoretical speculation of mine, and get as such.
Hi Sky,
i followed your steps, but i find a strong resonance peak on the Grenade at 500KHz, see screenshot.
Using severall other ground points and/or scope points i see different peaks, but no strong / single one around the 1.6 - 1.8MHz range.
Video here:  https://www.youtube.com/watch?v=gMLgvSw-omg&feature=youtu.be   (still uploading.....)
Not sure why my Grenade measures so low, perhaps i should remove 1 layer from the inductor coil.
Regards itsu
