0 Members and 787 Guests are viewing this topic.
Void
Ruslan also added the following:
"Everything else, add the following:
1.Kacher better untie nutrition from both the supply terminals + and -
2.Luchshe use MOSFET IRF460 (need to put a zener diode in the transistor gate. And best of 2 counter included)
Polevik will work better.  Experiments have shown :blink:
Tesla coil should be located on the same pipe as the beef.
The frequency must be tuned to the resonance of copper.
NMR frequency in both natural isotopes of copper.
Isotope Spin Natural
abundance (%) Quadrupole moment
(10-30m2) Relative
sensitivity Absolute
sensitivity NMR frequency (MHz)
at a field of 2.3488T Reference  sample
Cu-63 3/2 69.09 -22.0 9.31E-2 6.43E-2 -26.505 [Cu (CH3CN) 4] [ClO4]
Cu-65 3/2 30.91 -20.4 0.11 3.52E-2 -28.394"
___________________________________________
If you are wondering how Ruslan might have shifted from talking about pulling in energy
from the ambient to specifically NMR of copper, possibly this has something to do with it.
See the following two videos posted by Akula recently.
Akula is showing how the ferrite, (or possibly the copper or copper+ferrite) is showing resonances
not related to LC resonances, as best as I can understand from just watching.
"00007"
http://www.youtube.com/watch?v=Rz1CfbCDM44
"00008"
http://www.youtube.com/watch?v=qXS9vibWbb0
All the best...
Hoppy
Quote from: Jeg on November 07, 2014, 11:33:18 AM
Thanks Hoppy. What about the diode from katcher negative to the earth ground? Do you have it in your design? I see the radiant inside my circuits and it is imposed as an alternate signal over my low freq pulse. What can i say. It is a mind trick! How this high frequency seats on your low freq pulse? Looks like rectified as I assume?
I did not have the diode fitted during my experiments but I have tried it in circuit and it does not appear to affect operation.
The HF appears to be getting into the supply line because I've linked out the choke like Itsu. I need to find a suitable replacement.
John.K1
Guys,
Just thinking about the bulb test  ( bulb connected to the first output of the grenade coil and the second  end of the bulb free)
Why if I touch the insulated wire right before the bulb - NO light.
Why if I touch the insulated wire of the free end - MORE light
Why if I ground the free wire side - NO light
Why if I connect free end to three turns on the ferrite yoke - MORE light
Why if I connect free end to three turns and Ground on 12 turns coil on the ferrite yoke - even MORE light (such a small electron trap of Barbosa and Leal? :D )
Why if I connect free end to 12 turns on the ferrite yoke, no ground - NO light.
Answer? Resistance of load- capacitance - Inductance -  Maybe I will say a nonsense but is it impedance from our grenade we need to match for  best performance?
Thanks,
Hoppy
Quote from: John.K1 on November 07, 2014, 12:14:20 PM
Guys,
Thanks,
Hi John,
According to T1000 apart from the series resonant inductor circuit, this device does not primarily work as an inverter. However, my device is currently lighting my bulb by induction between the yoke windings.
MenofFather
Quote from: Hoppy on November 07, 2014, 06:19:46 AM
Yes, this is the hand-drawn schematic I based my build on and is the only one from him to my knowledge. I differentiate between a circuit diagram and a circuit schematic.  ;)
It may be that more capacitance is needed once a proper earthing system is established, which might account for why Ruslan shows paralleled 0.47uF caps in his videos??
This caps can be not for inductor resonanse, but nacopitelnie, how he cals them. He in 24 volts systems use nacopitelnie capasitors, who is siries with output coil and 28 turns coil on yoke.
