0 Members and 651 Guests are viewing this topic.
MenofFather
Quote from: John.K1 on November 09, 2014, 05:26:16 AM
D3x0R , guys
somebody was here suggesting the design of push-pul with just only  IR 2153 as on the picture below. Would that work??  I do not have TL494 at home yet so I am looking for some quick alternative :)
That work.
MenofFather
Quote from: T-1000 on November 09, 2014, 06:35:16 AM
The electric field is needed still! And the Antenna is your resonant electric field (with BEMF properties) source for grenade coil. Also due Tesla coil properties things too close make capacitive links and de-tune it if too close...
Here is some info from my experiments with Aidas:
https://www.youtube.com/watch?v=sAnfBemgyb4
The circuit used there http://filebin.net/y1ds4e533o/2_frequencies_mix_circuit.png is also organised pump but lacking split on inductive isolation between 2 signal sources and it has all what is required for Kapanadze coil.
The high frequency electric field source is from the left and current source from the right.
The stray frequency is injected into current and in http://home.dmv.com/~tbastian/ball.htm -
"...it became apparent that the fireballs resulted form the interaction of two frequencies, a stray higher frequency wave imposed on  the lower frequency oscillations of the main circuit....
This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence. It is but a step, from the learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent."   -N. Tesla
This is very important quote for FE devices.. Just instead of explosions the energy is redirected to load.
I think you wery close to free energy in this video, were tube burning.
T-1000
Quote from: MenofFather on November 09, 2014, 07:29:54 AM
The vacuum pentode was OK.
Also the main reason why we used vacuum tube was same as most people have - the transistors are getting burned when getting high BEMF voltage. So the vacuum tube can survive that without any problems... :)
Jeg
Quote from: T-1000 on November 09, 2014, 07:19:28 AM
..then synchronizing stray high frequency with main low frequency.
You mean in terms of harmonics? Without sync no effect?
Hoppy
Hi all,
I decided yestarday to re-wire my main earth and PC line filter exactly to the schematic posted by Enjoykin in post 6603. This has appears to have eliminated most of the HF interference on the PWM frequency shown in the scope shot I posted earlier under post 6520.
@ Mag,
Sorry to hear about the smoking of your voltage reg. I have found that these 3-pin these regulators will work up to their rated voltage with a smooth DC supply but often fail when used in inductive circuits. A good example is not to use them to regulate voltage to 12V for running PC type fans. They don't like spikes. I always use resistors to drop voltage for working PC fans. Its also very important to add a 10nF or 100nF ceramic cap on both input and output as close as possible to the regulator pins. My test supply has a max output of 25V and this is as high as I advise for these regulators for this application.
