0 Members and 101 Guests are viewing this topic.
Hoppy
Quote from: GeoFusion on November 20, 2014, 10:36:34 AM
Hi Guyz,
Within this vid you can see how charging cap works by tapping DC via 12V battery, Diode and inductor coil, Tapping is same as impulses as we know already.
Srry my way how I understand and see things ;D .
Start watching it by 3:00 and till 10:40.
https://www.youtube.com/watch?v=zTK91lHBPIs
Hi Geo,
That video was posted earlier but does not really explain how Ruslan lights all those light bulbs in his video from the charge in the caps he has his DVM across.
NickZ
   The magnetic energy that's coming off the switching induction crt, through the yoke or toroid is filtered and further amplified by the use of the right capacitor(s).  Allowing in extra energy from the ambient surrounding the device, rectifying it, dropping it to useful levels, and returning it to the input.  That's how it see it.
The tuning is what has not been replicated, as yet.
magpwr
Quote from: Hoppy on November 20, 2014, 05:53:17 AM
As some of us have suspected for a long time, Ruslan's hand sketches cannot be relied upon to give a proper insight into how he builds his self-running devices. There are important bits missing. The Kacher clearly cannot produce 1000V across the grenade coils rectified output cap. The statement from Ruslan posted by John.K1 above is also telling!! My build development is now on hold until I see something more convincing in the way of a circuit schematic.
hi Hoppy,
Lack of sufficient knowledge would indeed result in speculation of fake.
This is a video which show us how to to charge HV capacitor in less than 3 seconds using Kacher/Tesla coil technology with HV AVR plug in this case.
http://www.youtube.com/watch?v=WJUfj53geBo&list=UUEgxRqnEOzkvPUamxNwA9qA
Do you guys really need to follow the latest version without any sufficient details?.Think about it.
I am still at a stage in figuring on how to feed nanosecond pulse to device since the previous built."Still a work in progress".
My last attack point for nanosecond pulse will be the choke leading to the center tap of toroid/yoke.
GeoFusion
Hi all :)
Void,
Yes well aware that John.K1 posting that vid too. but it has to be understood and to remind us, that is the only reason why I posted it :)
learning material for us all. Yes it is what Don Smith was doing in his time, this is his technique too.
It's all cool about the Cern part man :), sharing thoughts.
Nick,
Yes very similair to the RMG, but yet as we know RMG draws to much amps at 12 or 24 volts, or even 36 Volts of which I tested
some time ago.
But this way with kacher to radiat Energy inside grenade coil is what we need and did a minor test when using rectifier bridge to
charge my 0.33 630V poly cap. (DC) non polar and charges it quickly and alot of spark when shorting it. It draws so little amps
from battery of PSU
The nanosecond or Frequency generator with one transistor or mosfet is in series with the ouput of the grenade coil and the cap/resistor to pulse the bit of energy that kacher is giving to the grenade and use to keep the capacitor charged full time.
It's amazing when we can understand this :), it's actualy simple, Gonna realy give a try on this.
And yes, the tuning will be the challenging part.
Good luck to you too Nick and thnx, lets keep it up ;).
Hoppy,
Hey, the vid was just to show a small example on how these caps can be charged, but doing this for us all here if someone does not
understand what is going on ;). It's learning material of basic-ness.
But for what I see is that this is a awesome approach for free energy. Actualy very simple I might say. but the tuning is necessary for sure.
magpwr,
That vid you posted is a perfect expample of Impulse to charge these caps to full charge or under a few seconds of use. :)!
now combine the knowledge and apply on the drawn schematic of Meno as how Ruslan discribed and drew his schem.
Fast charging is the way, and High voltage likes and needs the ground :),  gets more radiant energy from ground.
Cheerz guyz.
