0 Members and 349 Guests are viewing this topic.
Jeg
Quote from: Void on November 25, 2014, 09:43:54 AM
Hi Jeg. The odd thing is that in Ruslan's recent device configuration where he used only
the kacher driver, the voltage across his output capacitor was only about 1000V. I can get my
1 uF cap to charge to 1000V if I drive my kacher driver at 24VDC. His tesla coil output voltage
is probably approximately in the range of maybe 2kV to say 8kV max. The voltage on the tesla coil drops
the more it is loaded down. If Ruslan's latest device was not just a ruse to throw people off track  ;D,
then it seems there is something else going on that causes extra energy to get pulled in.
1000V across a 1uF cap is only 0.5J of energy storage. It may be that making some changes to the kacher
driver/tesla coil could have some real impact here however. I don't know. I continue to investigate. :)
All the best...
Absolutely agreed. I also believe that all the job is there. The higher the voltage the better the result.
Here is a video of mine for showing how radiant passes to the output without mosfets support.
https://www.youtube.com/watch?v=OsFuvUsaNlw
NickZ
  "my bulb can be switched from full brightness to cleanly off, just by moving my hand towards the Kacher antenna. The current draw does drop when the bulb extinguishes, so this is to be expected but what is causing the sudden switching?
  If I understand what you are trying to convey,  your hand is disrupting the Kacher's output, which in turn, affects the rest of the system.
This does not happen when Ruslan does that. What could this mean?
  A short video would be nice, to see what is going on there. Any cell phone can be used, if you don't have a camera handy.
Void
Re: Ruslan Pulsed Output Device
Menof, T-1000, or anyone else who speaks Russian, if you have time, can you give a short summary of what Ruslan said about
the output transformer windings (I believe it is wound on a toroid of some sort) on Ruslan's recent device? I am referring
to Ruslan's recent device as his 'pulsed output device' to differentiate it from his other devices.
Ruslan talked about the output transformer for a minute or two. Ruslan showed two drawings relating to the output transformer which I have labeled
T1 and T2, although it may well be just be two drawings referring to one single output transformer. It seems there is
something special with those transformer windings.
All the best...
Hoppy
Quote from: Jeg on November 25, 2014, 12:17:44 PM
Excellent video Jeg. Thanks for showing the two meters working together.
As you say in the video, it is important to initially ensure that the Kacher can be seen to light the bulb without the mosfet oscillator running.
Hoppy
Quote from: NickZ on November 25, 2014, 12:29:34 PM
It very likely means that Ruslan's video is as I said earlier - a piss take!
Just look at URFA's video to see what effect I'm getting. I will try to get set up for a decent video in due course.
