0 Members and 562 Guests are viewing this topic.
Void
Quote from: itsu on November 25, 2014, 06:21:59 PM
Jeg, Void,
i had this discussion about the 90° phase shift earlier here with menofFather.
I put up a simple test which shows that a current transformer introduces on its own a 90° phase shift even when measuring resistive loads.
I have a 220V/12V transformer which has a 12V/21W bulb attached.
I measure the voltage acros this bulb, the current through this bulb and the voltage acros the current transformer.
What you will see is that the voltage (blue) and current (green) are in phase as it should be with a resistive bulb as load
But the current transformer voltage (purple) shows a 90° leading or trailing (depending on how the probe is attached) signal, see screenshot.
https://www.youtube.com/watch?v=Nox5tkwjSNY&feature=youtu.be
Regards Itsu
Hi Itsu. Thanks for the comments and for the video. Ok on that. That is good to keep in mind that the current
transformer introduces a 90 degree phase shift by itself. What I was referring to however is not the initial phase shift
of about 90 degrees which can be seen on the scope when Ruslan has the kacher turned off. The phase
shift I was referring to is in regards to how the phase shift increases by approx. another 90 degrees to about 180 degrees
when Ruslan switches on the kacher. Have another watch of the video. This indicates that the tesla output itself is
introducing a 90 degree phase shift between the PWM inverter voltage (viewed on the output of the grenade I believe)
and the current in the inductor resonant loop. This in my view is very interesting and may correlate back to a drop in the
PWM driver input current. I can't say for sure that it does have this effect, because Ruslan does not show the input current
to the PWM driver, but I think that this is a possibility based on what Ruslan shows in the video. This may also explain why
Ruslan doesn't seem to have any synchronization circuitry in that device. A 90 degree phase shift like this when turning
on the kacher is not what I would call an expected result. It has at least potentially important implications IMO. :)
Nick, thanks for the updated video link.
All the best...
NickZ
  "So akula using the yoke only to drive - no kacher?
                                                          end quote.
  Not exactly, the HV is being superimposed on Akula's first device, by the 50 turn choke coil and its tuning capacitor, that are inside of the large air coil tube. The choke coil, is picking up the energy emitted by the yoke's 3 turns coil output coil, by induction. Which is also connected through a tuning cap to a 12 turn resonator coil, that is  wound on top of the big air coil.
No additional components as from a separate Kacher driver crt was used at that point.
Void
Quote from: John.K1 on November 25, 2014, 06:37:16 PM
I think most of thinks probably comes out of Alexej Romanov  (friend of ruslan, He is some HiTech electro-engineer)  btw, here is his video of selfruner for couple diodes based on Kacher Brovina ;) https://www.youtube.com/watch?v=PBNNRbhUUnA  Same kacher we have in Ruslans device.
  To understand what kacher Brovina is I was watching yesterday Mr. Brovin talking about some interesting properties of this kacher. It is in Russian so I have to watch it couple times o properly understand, So far  I understood it is really very extraordinary device. Check his video, at the very end he has some schematics.  https://www.youtube.com/watch?v=FNCPv19ujuc&index=1&list=FLPKuZ5HpxDHgqdk-z1JjKCg
Hi John. That LED circuit is an interesting circuit by Mr. Romanov. Since many of us don't speak Russian
however, we don't really understand what the circuit is doing. The kacher is just driving a toroid transformer
with some LEDS connected to the transformer output?
Can you summarize a few of the interesting properties of the kacher-Brovina?
What is the meaning of 'kacher' in the kacher-Brovina circuit? Was Kacher another person?
One last question. :) If you have a couple of minutes one of these days, can you listen to
what Ruslan is saying in the following video about the output transformer from about:
7:05 to 7:36 and
8:05 to 8:37
Just a short summary of any important points will do. :)
Ruslan seems to be saying that the toroid transformer is wound in a special way?
http://www.youtube.com/watch?v=yPkHNq6Wji0
All the best...
d3x0r
Replaced improvised JT with Mazilli oscillator
has to be a slightly higher voltage, but better output at 0.22A instead of 2.02A.
The grenade is actually resonating 1/2 the frequency of the mazilli...
not sure why that is... should adjust capacitances.
with this, the load affects the current... 0.15 with load disconnected...
have some stray capacitors that I have to sort out yet...
there's a voltage threshold that output goes up significantly for not a lot more input current...
but I dunno seems the pulses are lost... so it's more like driving it brute force with a sine wave.. and I think that won't get it there either...but going to tinker with it some.... though in this condition, grounding any of the output reduces the voltage in the output... so that's also why I think it's not right...  but I have to clean it up and see if I can't balance it better...
Edit:
kapagen coil is getting warm where it's counter-turned...
maybe I have more output than I think...
at 14V .27A I have <1mA through the load... at 16V .30A  I have >4mA through the load... (4mA is the limit of the meter, and changing to Amp scale says 34.2A :).... )
guess I'm going to need to find my zeners
ismael_34
