0 Members and 563 Guests are viewing this topic.
d3x0r
I don't know if I mentioned but my coil gets warm when generating higher power outputs...
https://www.youtube.com/watch?v=BO5YnF7BeOQ
https://www.youtube.com/watch?v=8_ayR33hcwc
ZVS driven kapgen w/ ferrite core...
it's 5-9W input... and 100-200mW output ... but the percentage of output increases more with voltage...
but; a ZVS has no sharp edges.  although sharper with higher voltage at the same frequency...
put a resonant capacitor from between the choke and coils to ground to reduce input and increase output.
really needed to put zeners ... think I shorted something somewhere anyway... but I almost don't want to push 18V.... But; if I put any low resistance loads (like incandescent bulb) it doesn't light; and it reduces the overall voltage on output (really should confirm what postivie and negative is)
Part of the reason I went with a JT driver is because of the sharpness of the edges... Similar to what the kacher output looked like on the overunity post of brovin video recently shared... it's kinda the same thing... was going to use just the one coil, and use the output of the kapagen to trigger originally; but couldn't get that to work...
was also down to almost 54Khz frequency...
Grounding any point on the output reduces the voltage on the output...
And (probably repeating myself) the load is now strongly visible on input power... but I guess 50 in 200mA is a more than 50 in 2000...
But really none of that matters, because it really needs a different sort of driver.
wish the output of TL494 was like 555 timer out
3x and X waves superimposed can end up driving one out ... and become more like a triangle waveform.
when I return to lower voltages 3x harmonics start showing up
further evolution flattens the top and bottom and increases the slopes so it is more sine-wave-like...
Jeg
Quote from: itsu on November 26, 2014, 04:37:50 PM
Thanks Void and Hoppy for your input / help up till now.
Jeg,  thanks,  not sure what you mean by "Ruslan sinus output with HF imposition".
Yes that is what I meant! Nice waveform. Do you see more difference (when you fire katcher) than that when you first showed us inside this black box?
itsu
Quote from: Jeg on November 26, 2014, 08:40:36 PM
Jeg,
this situation above and the one when using the black box are not comparable.
In the black box situation i had the circuit hooked up as normal, so Grenade to ground, 28 turn yoke, 10uF caps, bulbs etc.
In the above situation i mimicked the situation of the video presented by Ruslan where he had disconnected his Grenade coil
and hooked it up to a FWBR and some caps, so without the ground, 28t yoke, 10uF cap and bulbs.
I did create the above situation earlier in which case the superimposed output was way lower, but i was running on different
push pull and Kacher frequencies, see here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422291/#msg422291
Somehow the present situation is much more powerfull (Kacher is tuned to the grenade resonance frequency).
Regards Itsu
Jeg
Basically, yesterday i was trying to raise my Kacher's output. With my surprise when i put a mass of aluminum inside grenade's tube, covering the space inside between tesla coil and grenade, my output has got brighter. I suspect that Ruslan has inside his tube similar stuff. I will test to put inside a second tesla coil tuned to kacher's frequency to see if there is any more output increment. 24V supply for kacher is just not enough. It gives something but not at the right amount.
d3x0r
@itsu
can make some tiny capacitors to connect in parallel with grenade to lower the frequency slightly...
https://www.youtube.com/watch?v=mfeiMINnPJ4  (p2 http://youtu.be/p5JWn9lm9Cw )
Coil cap is 2-3m of wire ... maybe something like speaker wire or lamp cord in a length is a small capacitance...  (25pF... when you coil's capacitance is 150-250 that's like a 10-16% increase resulting in decreased in frequency)
plate caps are really multilayer which increased capacitance...then is variable by applying pressure... some people have nice variable aircaps :)
more experiments; changed mosfets... they end up with a double-ringback ... they're not overvoltaged; but instead of having the nice smooth mazilli curve it's got a ringback in it; although I can change condition so it does... but without it, the output isn't as good.... which really there's something about nice sharp edges that's a good thing...
