0 Members and 557 Guests are viewing this topic.
d3x0r
Quote from: Jeg on November 27, 2014, 04:35:11 AM
Basically, yesterday i was trying to raise my Kacher's output. With my surprise when i put a mass of aluminum inside grenade's tube, covering the space inside between tesla coil and grenade, my output has got brighter. I suspect that Ruslan has inside his tube similar stuff. I will test to put inside a second tesla coil tuned to kacher's frequency to see if there is any more output increment. 24V supply for kacher is just not enough. It gives something but not at the right amount.
when messing with the foil winding, it seemed to affect the inductance... requiring retuning... something about the diamagnetic field induced in aluminum mass... was an increase in frequency which is why I didn't attribute it to increased capacitance which would be a decrease... so seemed like a consumption of part of the inducted field...
itsu
Quote from: d3x0r on November 27, 2014, 05:44:16 AM
@itsu
can make some tiny capacitors to connect in parallel with grenade to lower the frequency slightly...
Hi d3x0r,
the Grenade is not the problem, the bifilar inductor is, as i cannot seem to get it into resonance at the Grenade/Kacher frequency
besides the push pull frequency it already is running on (not sure if this bifilar coil needs to be resonating at the grenade/kacher
frequency though).
Regards Itsu
d3x0r
Quote from: itsu on November 27, 2014, 07:35:31 AM
Hi d3x0r,
frequency though).
Regards Itsu
I see; what I understood it might be was a high current resoannt at a subharmonic... and the high voltage from the kacher... in theory to mix the 2 and have high power high voltage output... so at a harmonic, but not the same...
can you move your kacher top coil that's around the grenade?  you really want to keep it over the longest section... having it overlap was a destructive interferance
NickZ
  Geo and All:
   Last night I placed the same pieces of ferrite that I had used previously inside the PVC former tube of the RMG project. But, this time inside the grenade tube.
Although I am still using the small 200v fets (IRF634B), the bulbs did brighten up, as expected. They would probably get even brighter if I were using the normal IRFP260N fets, as they give much more output, and gain over the smaller fets.  So, maybe try some pieces of ferrite inside of the grenade, some time.
  I also placed several magnetite magnets inside and around the yoke core, and noticed an even higher increase in frequency, and output, as well.
  I'm still waiting for my order to arrive of the IRFP260N fets from China, but I'm doing what I can with what I have, for now.
  Although some may not agree, tuning the various circuits for maximum output, in order brightly light the bulbs, is not, neither here nor there.
  As just having a couple of dim bulbs glowing will not allow for a working feed back path.  And just high voltage, with little current to go along with it, is not enough, either. The higher the voltage is raised, on both yoke/grenade crt, as well as the Kacher, the lower the amperage will get.
So, you could have 1000+ volts, but can't hardly light the bulbs.
   Connecting the flyback core to my half wave bridge, and capacitor(s) for the feed back loop will be next. I had noticed much increased at the output, and at the bulbs, when I did this previously, compared to when I had not connect the loop back to the input.
bringdownthezog
Reading up on the circuits here these last few days got me to think there is something to harmonics after all. Harmonics MAY be the answer. Ive seen this effect a few times but did not pay attention until now.
If someone has a circuit to make harmonics in the vicinity of 10kHz I'd love to see it.
