0 Members and 123 Guests are viewing this topic.
Jeg
Some considerations, and a coil system proposal for Ruslan Replications.
https://www.youtube.com/watch?v=l7NN_nHQpDA
d3x0r
I managed to make some shots of various things.
0) the output diagram indicating cap names
1) both collectors on mazilli.  The gate is high the entire time of it's respective side... the dip is feedback from the grenade... kinda
2) one collector, and the resonant voltage that is used to gauge the remaining images... to align the phase of mazilli with phase of load and currents
3) current and voltage to the resonant capacitors (27nF) that brings the overall frequency down to 45Khz or so.
4) current and voltage to the series capacitor
5) current and voltage to the load
6) composite of 1,3,4,5
some of this ... like if I use a line that is series with the load to drive another kapagen coil I get a 3x (higher)output frequency on that...
FYI the math line is A-B function; not intending to show anything with it.
(scope shot green traces is 10x... probe set but not updated on scope... so +-150some volts)
<10V input
d3x0r
... ya know... with a mazilli driving the grenade.
Sorry to still be off topic.  Thought nick had a grenade and mazilli...
Okay I guess I'm so different in that I'm just bypassing the yoke and going direct to grenade....
current measurements were across a 22ohm resistor in series with caps...
think capacitor on the mazilli is about 36nF...
choke is 1.0mH
coils are ... probably 50uH (Edit: they are 13uH, 12uH and 40uH end to end...  that's 1/100th the inductance of the grenade )
Edit: chose wrong second picture before (third really.... 0,1,2, ...  added here... 2 is a dup of 5)
d3x0r
The problem is... the bigger that dip is, the more the output is, but it clips at a certain opint driving low enough to actually make the wrong side conduct... adding more capacitance (lowering frequency) is allowing that to be wider and deeper... and build taller on the front and back...
... but none of it is really 'enough' current... it's 2 seconds to charge 250uF to 100V...
but once it's charged it's like the 10mA input at 12V becomes 10mA output at 120V...
but the only thing that's good is high impedance loads... the flourescent doesn't light at all...well it glimmers.
Okay I did have a incandescent glowing, but I had to tap the connection between the two neons... and it disrupted the input frequency too much... different frequencies are strongly related to input voltage in this system...  if it were slightly higher voltage, and it would trigger a spark gap (a neon is not a spark gap) the incandescnet could have been lit pretty brightly... [size=78%]when it did the neons sparked purple instead of red.[/size]
555 timer's are not robust :) the output channel keeps failing.... disconnected from anything it looks like it works, but it has no power to it.... not enough to drive the gate of a mosfet...
Edit: Guess I didn't include the current to the cap on falstad sim...
so nothing really extra-ordinary?
