0 Members and 98 Guests are viewing this topic.
NickZ
  Void:
   Thanks, but that is just using the small fets that only put out about about 1/3 of what the IRFP260N can produce.  The circuit is running on an old, old, (50 year old 12v, 10ah) battery charger. As I don't want to burn out these smaller fets, if running them from my new 12v car battery, as they are the only ones that I have left, right now.
  The HV Ringer coil is running off of the yoke's output. But, they take too much draw from the induction crt that way.  I don't see any increase in incandescent bulbs brightness, only dimming of the bulbs when the Kacher is running.
  I'll be connecting rewound step down flyback core, to a bridge/capacitor, to run off of the yoke/grenade's output, and feed that back to the input, to see what happens.
d3x0r
revisiting the bridge rectifier devolution; I guess it could be an AV plug instead...
but then the cap has to have ground inside... so current can actually flow at a reasonable rate; the pF capacitance of the diodes transfers a little, but a lot more is done if a 3 plate cap is used instead
I guess it could be seen to be named 'NMR' since it is just the atoms of the copper and dielectric insulation that are participating in the resonance.... so AR?  Atomic resonance?
Edit; forgot the sim link...
Edit2; okay it's not really 1/4 the time it's more like 1/6th the time; it is however power amplified for a short time.
Edit3; and already 2 posts after this exist so... it's not that important
I found a pulsing conditiion, and a beat condition that's at 12Khz... not sure where that's coming from, I have no resonance on the bifilar coil...
I also found a fairly notable magnetic field... along the ground line... but really long the grenade... I should investgate that more...
From other Planet
Hello Jeg and a.king,
thanks for posting that benitez stuff, i didn“t see it before. But it insantly reminded me of following attached schematic from Antanas Homepage http://freeenergylt.narod.ru/ (there are more schematics from this Teknix guy under Anominus free energy section) and Ruslans strange diodes/cap setup. Some other free energy inventors also have very unconventional diode connections in their circuits...
My thougts on this:
Possibly Benitez schematic is showing one way of extracting radiant energy without killing the resonance (or is it "dont kill the dipole" like Bearden said?),  which is needed for radiant energy creation.
quote from chinese don smith replicator Ming Cao from PJK book:
"The most important issue, is resonance. Don Smith said that we should make the wire length of the primary
coil to be one quarter of the wire length of the secondary coil in order that they will resonate together. My
experiments show that this is not true. In a Tesla Coil, the primary coil and it's capacitor form a tank circuit
which is an L/C circuit, which oscillate at it's own resonant frequency, and when it does that, it generates a
longitudinal wave at that exact frequency. The frequency of this longitudinal wave is determined by the
inductance of the primary coil combined with the capacitance of it's tank circuit capacitor, and not the wire
length of the primary coil alone. The secondary coil with it's sphere at the top, together form an antenna,
which transmits this longitudinal wave. The secondary coil and it's top sphere together form a quarter-wave
resonant antenna for this longitudinal wave. They do not form an L/C circuit and that is why very few people
have managed to replicate Don Smith's devices."
kind regards
NickZ
  Guys:
   Please check out the Energy From the Ground thread, for a Barbosa and Leal type of replication.
   It's possible that this effect, has some similarities to what we are trying to do here.  Or not???
   Maybe some of us can have a go at this, also, as it's pretty amazing. If true.
d3x0r
Quote from: From other Planet on December 01, 2014, 08:35:12 PM
good call; adding 9nF capacitance across kacher primary helped output
the grenade is resonanting at 625Khz (no extra capacitance) so the kacher is at 625Khz... so the primary was 5uH... and 625 ays 9nF... I actually have steps of 2nF I tried... Think  finally settled on 6nF as best... (2 9's in series, and a 2.2 in parallel)
@Jeg
you should really remove one of the diodes that's between your coils now that you have the cap and coil each grounded... it's kiilling the ability to store enery
I have this resonant beat frequency at 12kHz at certain power...
http://youtu.be/feouUCRbd9I
I had another envelope ... so there was a long dead zone with nothing happening before a rise and quick falloff...
think the capacitance smoothed that out some...
played with the other I guess inductor coil (the other coil is antenna?) but it didn't matter...
and turning down the resistance between base and
Edit2: http://youtu.be/U3_A43HJ6Sg?t=1m37s  nice example of flashing output.
