Hoppy
Quote from: T-1000 on December 02, 2014, 05:53:10 AM
How big battery should be to run >1kW load extensively for 20 minutes?
The answer suggest to throw away this suspicion...
??? Certainly not a 1KW load for 20 minutes in this video I took the clip from: -
https://www.youtube.com/watch?v=yPkHNq6Wji0&list=UU_zn0cdzv_qfsxQUm4e7R9w&spfreload=10
d3x0r
@Any
what makes current meters run backwards?  The power supply is connected though 2 diodes one on positive one on negative, and a 25V 2200uF cap on the inside...
Fun with resonance at 625Khz :)
https://www.youtube.com/watch?v=NRN_jztQ0y0
I stumbled into a resonant range at 225Khz that had bright output; and high current input....
that's more what I would expect the frequency to be...
   1.881nF  266uH    @ 225Khz
at 625/550 the capacitance is only 234-350pF which is pretty low for a tightly wound coil...
I guess I should go back down... but then again, at 650k I see a FFT transform that indicates a 3Mhz sort of range ( <3000/1400/680 - 1/4 wave difference almost)
.... Hmm investigate high frequency back current?  or lower frequency higher output?
playing a little with the negative current state; replaced diodes... same thing...  but again they may be slow cause they're large volt/amp parts...
but... could draw a 3mm spark off of flourescent sitting in a fence post cap attached to the end of the antenna....
transistor gets a little warm...
still stuck at 63V output
NickZ
  Ok, guys. Last night after watching the Barboza-Leal replication video, I tried putting a capacitor(s) on my earth ground line. Where the ground line connects to the induction circuit's 3 turn coil's 0.47uf capacitor (ground line side of the cap).  And, it does help to increase the bulb brightness a bit. Maybe give it a try.
I just don't know which cap is the best to use. So, I'm just trying out the different ones that I have on hand here, first.
   Geo: It seams to me that your RMG was a partial success, and I'm sad to think that possibly with only minor changes, and better batteries, it may have been real self runner. Doesn't matter if it ran using the battery, if it can keep it  charged up all the while it's running the lights as well.  As even a new fully charged car battery would not have lasted 5 days on your load.  No ways...
That is what I'm still working on, but now using the yoke/grenade/Kacher  system instead.
   The idea that the Mazilli is a power hog is true, BUT, does that really matter if it will self run???  More power out than coming in, may not apply in all cases.
  In any case, my circuit is only the bare-bones, no cost built version for now but, with the thought of improving on it in any way possible.  As I also don't have too much faith on any diagrams, or unverified devices. As too much time and years have past, and still no working replicatings, at all.
Enjoykin
Хм Хм Хм Хм
If everything are hidden batteries what is your purpose being here ?? Go find another job, play football , search for aliens or order @WHITE HOUSE@ to uncover more than 5600 stolen free energy patents !! (And all John Worrell Keely OU-machines)  ;D
Information is from Dr Steven Greer videos.
Ask him here for more details:
https://twitter.com/DrStevenGreer
Who want watch this video and make own conclusions
Резонанс в качере- лампа 60 Вт потребляет 30 ватт!  :D
Katcher Scalar resonance -  In 30 W, Out 60W.
http://www.youtube.com/watch?v=EqZFr31Byvk
It well know fact that Great Nikolai Tesla is a source of all our Ideas.
Tune supply voltage and find a TARGET POINT. With Grounding output is higher. Best variant Big Tesla Magnifying Tramsformer. Katcher Brovin is small Tesla transmitter. On hot end is small Avramenka plug from two several pico-farad HV capacitors. Any HV diodes 15KV can be used here instead.
Confirmed News are Roman Karnouhov has sold his 2kW OU generator to Germans for 600 000 euros. And obtained new 4 channel Hameg 500MHz oscilloscope and other lab equipment.
So question is:  Does American governement will permit Germans to make and sell Akula OU generators from 2kW-10 kW or not ?? Kapanadze didn't permitted.
What about it old grandmother spaewife Vanga has said ?? You decide !!
Btw Original Tesla schematic how to convert high potencial to hig current you wil find in Tesla - Lectures, Patents and Articles in Dynamic currents topic.
OK you are on your own.
Good Luck !!
stupify12
Hi Jeg ;D
The way to extract this energy Jeg is using the Radiant Energy Patent of Nikola Tesla. Make it simple so you can think clearly instead of deeply.. I congratulate you for obtaining the Radiant Energy phenomenon..  Yeah.. Tesla Pancake or Spiral Bifilars is the source of this still undefined phenomeon..  There you go, keep on working on it and follow nothing else just NIKOLA TESLA. Tesla call it Radiant Energy because this energy is in a form of Radiation which we are still unaware of..
Meow  8)
Quote from: Jeg on December 01, 2014, 05:07:17 AM
Well Void, if it is to vote then, no.2 has enough chances if a relay or thyristor is being used to discharge these caps to a load or to a second capacitor.  And as i see it, without discharging a cap we will never pass on the other side (OU) with just using Ruslan's circuit as it is. The dumping effect as Tesla described it is not present in those publicly published circuits. Anyway. Take a look of some things that give rise to kachers output affection to the output, but as i already told this is not enough to make the transition to the other side.
https://www.youtube.com/watch?v=4536mMgOjv8&list=UU_HNW6MviMNNhdWRBtG5i3w
ps. Meow congrats for your last post. Two spiral coils which act as capacitor plates. The same happens here, but using Tesla's spiral bifilars is the way to take the sh..t out of the system!  ;)
