0 Members and 78 Guests are viewing this topic.
stupify12
Wooaah Jegg. You are now on the right track..
Yes. This Carlos Benitez is the same working principle on this Free Energy Device. What people dont know why if you replicated Carlos Benitez will not work for them because of the SILICON Diode. Jeg focus only on this people, Nikola Tesla, Carlos Benitez, Plauson you can find all the answer you need for a system to work. For Ed Gray only follow his writings but not his schematic diagram, Carlos Benitez Cathodic Valve is the same with the Ed Gray Tube = also the same with the Tesla Radiant Energy device. Which means everything that we call free energy device that works with Electrostatic Induction it all starts with the greatest of all Nikola Tesla..
Meow
Quote from: Jeg on December 01, 2014, 07:56:11 AM
Ok. Before some days T1000 was insisting that if we discharge a cap up to its middle voltage it would be more easier for katcher to re fill it in a related small time interval. The same time, i remembered Carlos Benitez design where he was discharging his cap (9) inside an other cap (1), which apparently at the end of the process both caps are semi-full. I see a connection on here.
In addition, in Ruslan's new circuit where he discharges his cap through a 300T coil with the use of a mosfet, he probably does the same thing as the coil itself will not let the cap fully discharge as coil doesn't allow sudden current discharges.
stupify12
Jeg,
Go go go. Keep pushing forward you have it man. dont be disrupted with those which is not the original one... You have the proof, that everything Tesla talk is correct and working why not proceed...
Meow ;D ;D
Quote from: Jeg on December 01, 2014, 08:47:45 AM
You find me totally aligned with this, but at the end i feel that radiant energy doesn't obey all the conventional rules that we have learned at school. Anyway, i think that everyday we come closer and closer. ;)
GeoFusion
Hi Guyz  ;)
I feel that we are close to figuring a great Discovery with Radiant systems. :)!
jeg,
yeah man :) lets keep it up and keep on experimenting and brainstorming on this.
We have the necessary knowledge now to make many things and come done .
Charging caps with radiant being rectified to DC is something new for me now past weeks.
But I do see now using and NST or flyback would do the same work. Rectify the output from output coils maybe not direct from NST and flyback.
but manage to make a spark gap device like Don smith and the rectify the output and using ground with the caps :) as we know already.
Tesla did this many times  ;D. there you go hehe.
Well about Ruslan, I don't think he is making other devices in order to deviate others from replicating for what he has build in the first place
I really see that Ruslan is simply showing us other findings and simpler methods to understand what is truly going on in these devices.
I think understanding the latest will give the answer automatically to understand his other builds  with yoke core and bifilar set.
I really do see that maybe the yoke is being used to pulse radiant that would be rectified via the diodes and charge the cap fast.
but as what I see in the previous Ruslan devices replications are also Fine tuning to able to make it work.
But main focus is how to go about with the Radiant energy ;).
This all will let to understand Akula systems too, They both talk about system using Radiant energy.
I remember when watching the latest vid of ruslan, I hear him talk about Vasmus system in relation for what he is doing in latest device.
But it's same way charging caps as what don smith does but differently.
btw check the links below.  some amazing updates of ppl I know and in contact.
  Hoppy,
I'm sure this guy ain't faking nothing here, I really do see it's going to a legit path, also by my findings trying a replication.
Lets keep a positive thought towards this ;), we are so close, can feel it.
  d3xor,
Thnx  for pointing out  on the pics, they would be of good use while experimenting to see results.
  Nick,
Yeah man I was at it some time ago , the barbosa- leal experiment, but had no luck but discovered many things but this vid changed everything. vid below. guesing that is the one you are referring to?
Yes the RMG was a partial success but a powehouse , high power, but can be adjusted with this new method.
yeah, i really think with new batteries, it would be alot longer and much more efficiently never tried it befor. but can let it deviate me for
what I have to work on now  ;D.
I just know the mazilli on it's own won't self-feed-run a system without batteries,  unless you add a high voltage pulse / spark gap tech to it with HV caps,
maybe then it can and most likely to add the ground to it.
I will keep up with the posts and findings, as what I want from everyones side to experiment and check out ;)
Enjoykin
thnx for the upload pic.
All.
Awesome Finding by this man about the Barbosa Leal Device.
watch it completely, He has figured out something amazing. Using a cap to the ground. Only using the Hot line.
https://www.youtube.com/watch?v=lUtRFSqj504&index=5&list=UU90HtxBQXQvSDsBG_TJqV_A
This is a friend, Nelson Rocha building a Radiant collector and then pulsing the radiant into cap fast.
Great finding and this is what i was talking about, collect radiant, recitify and then pulse it.
https://www.youtube.com/watch?v=C9Ozeq61x1Y&list=UU8Bo71izl8948rCESU6x8Lg
Cheerz
a.king21
Geo et all:
I spent a good 2 weeks trying to replicate the Barbosa Leal. Then I did some digging.
They have 4 patents of which 2 are obviously fake.
Secondly, Brazil uses SWER. Single wire earth return for it's national grid system.
This means you can extract energy from the ground using just 2 earth rods.
I also tried caps etc. Didn't work.
If someone can replicate this system in a non SWER country that would have much more validity.
On the Barbosa Leal thread one guy spent thousands of dollars buying a used Barbosa Leal system.
He took it apart and found nothing special inside. He was also told to put in a huge number of earth rods.
I guarantee you that any of us on this thread could get energy from the ground in a SWER country.
It is effectively stealing from the Grid. I am sure the Brazilian government does not want this information
known publicly.
pulp
Quote from: a.king21 on December 03, 2014, 12:49:51 AM
Geo et all:
known publicly.
Wow free energy  :D
http://www.aprs.org/aprs-swer-test.html
