0 Members and 359 Guests are viewing this topic.
Void
Quote from: T-1000 on December 08, 2014, 06:09:44 PM
In Kapanadze/Dally/akula/Ruslan devices instead of that plate you get grenade coil which is receiving that charge and also has connection to the ground. Since the antenna from the Tesla coil is "hot" end if you would look in a way it is a capacitor plate the second "cold" capacitor plate is the grenade coil. And due coil geometry the windings are making up standing wave nodes which most likely are functioning as electrons trap when the current is being drawn from Earth and given back...
Hi T-1000. Yes, what people have been calling the 'antenna coil' is a misnomer IMO.
This large diameter wire winding is acting as capacitive top loading for the tesla coil
and it is coupling to the grenade coil primarily through the electric field. I have confirmed
this in my own testing. From that point forward I don't know what is pulling in the excess energy,
but I would say it seems pretty likely based on my own tests that if this is to work, that exact operating
frequency of the tesla coil is very likely an important factor.
Here's something to consider:
Simple radio antennas often make use of earth ground, such as quarter wave or similar vertical antennas.
However in the case of radio antennas, they often employ many ground radial wires spreading out from the
vertical antenna through the earth, or just above the ground somewhat, to reduce earth ground losses. Such antennas
can generate very high earth ground currents however, depending on the power being transmitted. The purpose with antennas however
is to radiate EM waves, but in our case we want to contain the energy and direct it to power loads. There may well be some similarities here however.
All the best...
Enjoykin
Quote from: T-1000 on November 24, 2014, 03:15:23 PM
From now I will be ignoring your posts. Getting called as troll second time is not fun anymore and the Marinov setup has nothing related to Syairchairun's setup. If you are blind not seeing that in http://www.overunity.com/15088/new-generator-no-effect-lenzlaw-give-more-detail-in-pcture/dlattach/attach/144160/image// (posted by syairchairun in http://www.overunity.com/15088/new-generator-no-effect-lenzlaw-give-more-detail-in-pcture/msg423162/#msg423162 ) that is your personal problem...
!! ON ENGLISH !!
From November 24, 2014, 09:15:23 PM
T-1000
YOU DID NOT LEARNED TO KEEP YOUR PROMISES IN YOUR LIFE !!
I THINK NOW IS A PERFECT TIME TO BE A MAN OF HONOUR AND TAKE YOURSELF A LESSON!!
ps: I really have not seen any effect of your jumping from thread to thread and flooding and disinforming people. Do people BIG FAVOUR - STOP COMMENTING
Have a nice day
Enjoykin
Хм - Одна баба сказала....  8)
skywalker66
Quote from: John.K1 on December 08, 2014, 12:47:51 PM
One is asking- why Kacher in this design? Why not  discharges?
Hi John !
I've not pretend I know for sure, but lets put tings together.
Kacher in this setup will create HV positive pulses on antenna, related to ground. (If is true what ruslan showed a diode between kacher emitter and ground, cathode's diode to emitter). Due to displacement  effect grenade will be negatively charged (ie electron surplus attracted from ground), like a HV capacitor, one plate antenna, other plate grenade.
More than that, those antenna positive pulses must be on natural grenade frequency. It is known that a coil like kacher secondary or even like grenade at resonance act like a lumped LC parallel crt. , having a huge impedance (theoretical infinite). That is very important, I don't know why exactly, but it is.
That kacher can be replaced by a HV transformer with ferrite driven at grenades resonance freq, but from my experience, this kind of ferrite trans won't work well at that high frequency.
As you saw till now, grenade if wound in 2 counter directions which made 2 opposite magnetic fields. This field configuration act as a trap, containment for charged particles - it this particular setup electrons, attracted from ground by means of antenna.
There is more to experiment and understand.
Hoppy
Reference the effect of the Kacher on the grenade coil. I feel its worth repeating my primary observation where I found very sharp tuning points whilst moving a bunch of ferrite rods through the centre of the Kacher secondary coil where I could completely control the grenade output. The bulb load could be taken from fully bright with 230V across it to no illumination where the filament did not show any red glow. The ferrite rods were acting as a switch. The bulb was lit partially without the ferrite rods inserted. The input supply current always tracked the output: bright bulb, high current: dim bulb: low current. At first I did not feel that this effect was caused by induction as I had wide spacing between the antenna and grenade coil. However, I had failed to take into consideration that there was a huge step-up turns ration between the six turn antenna and the multi-turn grenade coil.
It is often assumed that the Kacher secondary with its antenna / top load is an open ended circuit but in reality there is a capacitive return to ground and at very high frequencies it takes only a few picofarads to allow a significant current to pass through a load connected in series with the air cored grenade coil. Although, the grenade coil is heavily loaded, with transformer action between antenna and grenade / induction coil, sufficient voltage is available to fully light a 40W bulb having a 'hot' resistance, in my case around 1200 ohms. To me, it therefore understandable why those experimenters like Nick have more difficulty fully lighting there bulbs designed to work at 120V, where the supply current needed is double that for 240V working.
My conclusion is that contrary to my first thoughts, the Kacher was inducing a considerable current into both the grenade and induction coils and when a resonant point was hit by tuning (maximum amplitude on Kacher secondary waveform), a high current was induced, which lit the bulb brightly and had the effect of warming-up these coils considerably in my case. I find it more difficult to explain why the bulb could be extinguised by hand capacitance / loading of the antenna. I think it possible that a phase cancellation is causing this and I recall that this matter was raised in earlier posts. Can anyone shed more light on this?
Jeg
Hi guys
I am almost sure that katcher's reduced performance is not the problem of not getting OU results. Ruslan's Katcher is also very weak but his device performance is over unity. How you explain this?
In my kacher's experiments i give it almost 5A at the input and outputs more than 20-30KV just to see the affection at grenade's output. Yes it gives more light at my output bulbs, but not even close to OU even if i consider katcher's consumption 0 A. For me, we should see OU results without Katcher first and then to amplify them with Katcher's usage. Katcher alone gives nothing. 60W that you are talking about is nothing compare to 1 and 2Kw  of Ruslan's results. What makes you think that with the combination of grenade and kacher we will have something more than what we are already experience? I believe that our mistake is at a conceptual level and not in a technical level. The sooner that we will see it and improve it the better for all of us.
