0 Members and 51 Guests are viewing this topic.
d3x0r
Quote from: Jeg on December 11, 2014, 03:39:19 AM
I think that d3x0r's way of attaching galvanically the output of the secondary through a cap to your grenade circuit is a good method. I haven't tried it yet though as i have dismantled my device for testing some other topologies. Any way of amplifying katcher's affection to the rest of the circuit will be welcomed here. But, as i think this is not the point. This will not give a self runner by itself.
but then, how do I know what is responsible for the resonance... realized I wasn't getting any more voltage in my caps than I had on my kacher alone...
so I went back to an antenna... and at high enough current got it to sync with the grenade and make output; but think I was missing the reonsnace again; cause again the output was no more than the kacher itself.... and really an antenna is low uH to high uH (grenade) should be a stepup transform..?...
getting some higher caps and diodes soon to test with...
d3x0r
Quote from: Hoppy on December 11, 2014, 03:56:50 AM
The description I gave was with both the push-pull and Kacher working. When the Kacher is switched on, the bulb can be taken from low light to full brightness by tuning and then to no light output just by hand capacitance - moving the hand close to the antenna.
while testing last night with antenna, I found that at a certain distance from my hand to antenna I could improve the brightness... and what that caused on scopes as a higher frequency oscillation on top of the other normal 'resonant' wave...
the kacher itself wasn't oscillating faster; that wasn't enough to make it back to the base to cause oscillation... but it was definatly there.
Also noticed last night while tuning it... if I increased the voltage while it was at a high frequency... I could build a charge in the output cap; once this got to a certian level, if I reduced the voltage, it would kick into a  higher power charging of the cap... taht I could then again increase the voltage and get a good charge... but... it was no more charge than the kacher itself...
Void
Void, your dancing sinus waveform rocks!!! :D
About what you asked, it is as you said. Normal primary and secondary, a thick coil at the top of the secondary, and one cable connection from this thick coil to any point in the circuit of grenade. Try attaching it to several points to see the difference. I think that d3x0r's way of attaching galvanically the output of the secondary through a cap to your grenade circuit is a good method. I haven't tried it yet though as i have dismantled my device for testing some other topologies. Any way of amplifying katcher's affection to the rest of the circuit will be welcomed here. But, as i think this is not the point. This will not give a self runner by itself.
Another thing is that as much as someone raises the mosfet's voltage, the HF katcher's output voltage that is being induced at the output grenade circuit is getting higher (without raising kacher's input consumption).
Nick, when you speak about jumper do you mean about the ground connections? Cause there is not any other physical connection between the two circuits.
Ok i have asked you again but i forgot. Is Akula's second circuit device the one with the two mosfet coils on the yoke core which lights some led arrays at the output? Man your output load is way too high to notice significant difference with the use of katcher. Try some 50W load first to see if there is any impact of katcher so to check if your circuit can transfer katcher's voltage at your output load.
Ps. Void, at your video waveforms, is capacitor connected at the +- output bridge points or at the AC input as Ruslan's related drawing?
Hi Jeg. Thanks for the comments. From my own testing, when using the 'antenna' coil, the tesla coil already is coupling to the grenade coil
primarily through the E-field. Akula's 'second self runner' is the circuit that Ruslan has replicated in many
of his recent videos. The same circxuit that many people here have been experimenting with recently. The 1 uF cap is connected to the output
terminals at the FWBR (+ and - terminals), exactly as I showed in the test configuration schematic in my first video.
All the best...
NickZ
   Guys:
   It looks like we may be getting a little closer to seeing something interesting going on, while doing this Kacher/grenade tuning bit.
  After the last few comments I tried my set up, to light a small ac bulb on the grenade output. If I just use the small 110v bulb I do get a brighter light on the bulb when the Kacher is also connected.  And, my hand near the antenna can make the small bulb brighten up, or dim as well.
So, far,  so good...  I'll make a video of it when I get further along.
  Looks like the Kacher pulses are turning the Mazilli/grenade crt into an RF signal transmitter/receiver, as mentioned by some guys previously.
"Nick, when you speak about jumper do you mean about the ground connections? Cause there is not any other physical connection between the two circuits."  end qoute.
  No, I mean the connection from the yoke's three turns tuning cap (0.47uf), which is connected ALSO to the yoke's/grenade 28 turn coil, as well as earth ground. But, my earth ground line is connected to the other side of the tuning cap (yoke's side of the 0.47 turning cap). That's where the ground connection works best on my circuit, and allows the small AC bulb on the grenade's output to light up brighter.
stupify12
Hello everyone  ;D
I have read all your post, comments and suggestion. I ask of those who has worked with a Kacher circuit did you get a good results? Anyone?
This is not a discouragement but a suggestion for a better development on this project.
The secret you are looking for has been answered by Enjoykin many times. The Ruslan and Akula schematics are very pleasing to your eyes, but if follow those Coil Winding or Coil Arrangement you end up in failure.. I think all of us here knows that this Ruslan, Akula, and many others which has succeed on this Free Energy device has research only the work of Nikola Tesla. The answer which you think is a secret has already been in you memory drives(Brain).
The very first hint to success on this device is what Tariel Kapanadze called  "Tesla Transformator" which he is actually telling us the Tesla Electrical Transformer patent which also Nikola Tesla elaborate more this device on his Book.
Why the Akula or Ruslan device needed a Kacher circuit? On I have observed, which was also tested by me. When I try to directly connect the Tesla 1 Wire Transmission to the Receiving Transformer the bulb attach will not light even a little, also the capacitor attach in a Radiant Receiving Element fashion is not charging. But if the Tesla 1 Wire Trasmission line is switch thru a Spark Gap, the bulb will light brightly, the capacitor will discharge automatically on its own terminal. When another windings are rectified to charge Capacitor can run a DC motor when attach to this capacitor.
What is lacking is a conversion of this electrostatic charge in a capacitor to be switch by another switching Electronics or Spark Gap that the frequency will be 60hz with smaller potential(voltage), greater amount of current(amperage). Like the Switching Power Supply does on the computer PSU, Convert the stored electrostatic charged in a Conventional way like all of us here knows then feed it back to your device..
Meow 8)
