0 Members and 149 Guests are viewing this topic.
John.K1
Guys, Ruslan has new videoon YouTube since yesterday  https://www.youtube.com/watch?v=xPjELtEEtq4
Generally what he says is - short impulses on antenna (up to 500ns)
On the picture where he shows the magnetic field he says you must give it the impulse not at the top of the amplitude rather a bit on the side.
Next think is the inductor coil has to hold/keep resonance . In overall he says it is resonance in resonance.
Partially I do and partially I do not understood what is he talking about. Can somebody tell me how big is a magnetic field he talks about, around the Tesla coil?? As far as I understand the HV is like a static electricity. The size of magnetic field depends on the current. No current no magnetic field. So how can magnetic field be the main process in this device???  It looks to me more like a big capacitor with the inductor coil in the middle.
BTW: He doesn't want to show any schematics nor sell his device. He says he wants you to understand it and build your own schematics ;)
Thanks
magpwr
Quote from: John.K1 on January 11, 2015, 08:38:12 AM
Thanks
hi John.K1,
I did saw the nanosecond pulser circuit once more and looks like it's going back to the PWM generator via blue/black wire from nanopulser circuit.
I can't tell if he is modulating nanosecond pulse with pwm generator which may cause the dual output to produce square wave but with many pulse within the square wave ~500ns.
He is hiding this portion very well from the public.
I did sent Ruslan a message in Russian in youtube comment  after sorting the sentence in Russian.But no reply since as usual.
ok i have just spotted a comment from Ruslan to someone in youtube which i have translated  which may prove my theory that he is modulating the ~500ns with pwm generator.
Frequency inductor 28-32 kHz, but the pulses whose duration is equal to 1.8-2 MHz and there is need for strikes. Kachernye pulses can be served by one half-period. It's then I'll tell you.
Tomtech29
hi.
have showed up many practitioners installers which increases the chances to prove the truth,and that's something the success of all. Mentor says the share but scant full illustration of the signals,sure many would agree Ruslan thanks for that!
The question remains how the block was made to synchronize and silencer does not enter the pulses on the LC 3 windings is a condition for the stability of the system is preserved.
Another important foundation is provided (injection) a high pulse at the top of the sine wave.And it's no so much in this topic- yes, we know from the voltage and current is too greca bridge rectifier, power DC electrolytic capacitor many changes ?
- here my question is what the capacitors in the power supply they suppress resonance as referred to on it blew Yes or No?
electronics guys is a hard nut to crack,lack of good footing schematic / diagram (like folding puzzle in the dark)you have to try the shakes like hell :D ;D smile to author Mr.R
P.S  How is this impulse to the ambient air and where measurement is taken?
John.K1
Anyway, the task is to hold resonanc on the inductor coil and make sync to Tesla coil to get impulse right behind the top of the amplitude on the inductor's LC contour.  Piece of cake :D
BTW- I am thinking to make sharp impulses by using the small discharge tubes. I have some at home and making some experiments  with that right now. ;)
(discharge tubes  :  http://ie.farnell.com/webapp/wcs/stores/servlet/Search?st=discharge&catalogId=15001&categoryId=700000006299&langId=353&storeId=10163"  )
GeoFusion
Hi guyz,
many don't understand  how this device is working and
why Ruslan wants you to understand it and try to build if you can.
I will give a tip.
About how these devices work,  you have to understand how it harnesses Ether/Cosmic rays/Radiant energy that surrounds us all
like a sea of energy ( take example for lighting), and convert it into usable heat energy stored within condensers/capacitors.
by storing and using it on demand. it will come out High frequency because of The High voltage system(which activates this harnessing effect) and push pull system, nor will it be 120V or 220V at output unless you have the coiling in such a way ;).
Our planet is not only being bombarded by Radiant energy particles from the Sun and the rest of the other stars continuously,
but it also comes from our Inner sun that radiates it outward.
THe reason why the system uses Ground line and harnessing it this way,
acts like a harnessing Antenna.
One more tip,
" Work backwards with this energy" not the conventional way.
understand how a Telsa coil's top load attracts.
Cheerz :)~
