0 Members and 66 Guests are viewing this topic.
lost_bro
Quote from: magpwr on January 24, 2015, 12:31:45 PM
hi lost_bro,
I am currently working on PLL in virtual electronics environment. :D
The schematic posted in youtube related to Dave lawton was wrong.Back then i had insufficient experience with PLL.The resistor on pin 11 and pin 12 for 4046 should not be the same.
Resistor value for pin 12 should be higher than pin 11.The original diagram found in internet was worst ,pin 12 on 40426 was left unconnected.This cause the circuit to stop function mid way. :)
This project can be improved further if you can coat the 316L tubes with "Super corona dope"."I can't seems to get this stuff shipped out of USA back then"
I abandon this project due to safety concern due to confined working area."I may resume this project if i have run out of ideas on kapanadze"
My old video revealed what we can achieve using only 1 watt of power <5volts in order to split water.
This was the last video -
1 watt HHO generator ver 2.0 -More bubbles produced with 2 HHO tubes to 1 bifilar coil(Just tap water)
https://www.youtube.com/watch?v=NJw4SSjnejM
HI MagPwr
If I remember correctly Pin#12 is the voltage offset for the Frequency range adjustment and can be left unused.....
His circuit has other limitations/drawbacks that I don't like too much either: ie; Hard switching on the Gating cycle,  the circuit will turn off the MOSFET arbitrarily during ANY part of the Switching waveform.....
Can be corrected by logic gates to time on leading edge and synchronize the switching signal (ZVS), easy mod, use a 4013N or 74HC74D flip-flop > AND gate: Drive signal > CLK & interrupt from GATING > D > AND gate.   Has to wait for cycle to complete before terminating MOSFET drive signal (output of Q only changes on next rising signal edge ).
Funny you should mention Super Corona Dope:  I have a bottle on the shelf from a number of years ago when I played a bit with the DL PLL also.  Never opened it,  one time used standard electrical varnish on the 316L tubes and it adsorbed water and eventually peeled off the tubes.
Sorry for the sidetrack......
Yes, PLL or  a *Phase Lead feedback driver* might be the way to go for small signal/logic control for the Ruslan device.  These are exactly what is used by the DRSSTC builders.  Learned alot myself about signal timing / resonance building SSTCs.  I believe some the same information is applicable in this case also.  Just how to apply it?
take care, peace
lost_bro
EDIT:  forgot to mention the good part of the DL PLL:  I really like the frequency autoscan for resonant freq.    Of course the values Dave used are for just a couple of KHz.....   would need to change some resistor value(s) to get the right frequency for the Ruslan project so the autoscan function and PLL would scan & lock at desired ballpark frequency range. (maybe fix so it will ZVS also)
verpies
Quote from: Hoppy on January 24, 2015, 04:31:44 AM
This new version is not shown self-running and the lamps are running at very low power in comparison to their ratings.
I am not following this thread much so I don't know what's going on.  I see some scopeshots - that's new!
Could you summarize it for me?  Why has Ruslan switched from a self-powered to externally powered version?
Does he answer questions in Russian?  Is anybody translating his videos to English?
Void
Quote from: verpies on January 24, 2015, 03:16:33 PM
Hi Verpies. Ruslan has built several different versions of supposed self running devices, with most of the recent ones
being based somewhat or closely on Akula's second self runner. Ruslan seems to be trying different arrangements to try to
get more output power, and also apparently to try to get a more stable device. Ruslan sometimes posts a video of some testing
he is doing on a new device arrangement before he makes it self running. His latest device is using a lot more
circuitry such as waveform timing sync circuitry, and possibly some circuitry to try to control frequency stability, and
I don't know if he managed to get this latest device self running yet or not.
All the best...
Hoppy
Hi Verpies,
Void has covered the background well. What I find fascinating about Ruslan, is that he is spending a lot of time and effort producing a lot of videos and comes across as a serious experimenter. The waveforms he shows are easily produced from my attempt at replication. However, I have observed nothing that in any way convinces me that his devices actually self-run despite his self-running demos. I feel that he is sincere in believing that Akula has been successful and is trying hard to find the secret by basing his devices on Akula's. I do not think he is holding back anything, rather that he feels the need to fake self-running to seek maximum attention in the hope that others can help him to success by sharing his observations and build details.
John.K1
Hoppy, it is exactly how I feel it.  I said it here also before it looks like he is trying to get some infos from Akula ,pretending he knows the technolgy yet. Anyhow, we keep going- the free energy is there somewhere :)
