0 Members and 721 Guests are viewing this topic.
magpwr
hi everyone,
There seems to be improvement in PLL circuit diagram released which can be used for Ruslan device.
This morning i just tested out the nanosecond generator in virtual using 74HC132 which is little more simple than my design(less 2 diodes).
The PLL in this circuit is designed to lock onto frequency between 17khz to 42khz.
My experiment revealed the blue toroid is the best one i have in order to generate nice moustache waveform for LM393 or better waveform using TLC272.
The short tesla coil i have previously assembled merely generate around 1.3kv at 30volts using nanosecond pulse at around 27khz  to base of transistor 2SC5200.
I have made a wrong move by removing couple of turns in order to increase frequency to around 1.7Mhz with Antenna.
Using my another tesla coil with few hundred turns(resonance at around 533khz) combine with nanosecond generator did produced "negative ions".
By placing finger near coil i can feel "cool breeze" without getting burned or shocked as long i don't touch wire.
I am very sure by placing small incense candle nearby i can easily make fire to flicker.
The voltage generated from this coil is peaking around 2kv...3kv at 12volts .
balphom
Wesley i have learned a lot from the videos you were translating and i have a request that you continue to translate for people like me who don't understand the language of the Russian. Even if  the last video of ruslan. Thanks in advance
Void
Yes. it would be much appreciated if someone who speaks Russian could maybe provide
at least a brief summary of the important points in Ruslan's latest video, since Ruslan
is going over how he believes all parts of the Akula device work. Maybe there is some new and useful
info in this latest video?
All the best...
