0 Members and 1116 Guests are viewing this topic.
MenofFather
Quote from: Tomtech29 on March 08, 2015, 07:22:13 AM
Hello friends wanted to say hi to all community participants.
Thanks to search for a new plan -current project comes from one gentleman who shared the blessed time,I decided to make a similar experience Unfortunately, somewhere something done incorrectly.
Please correct me/ participant of the forum called:magpwr used the simulation very helpful I would be grateful (if you wanted to see and test).
You can try simpler version.
MenofFather
Quote from: Tomtech29 on March 08, 2015, 07:35:59 AM
The problem is the lack of power at the site of the restriction (20uh)  to the stabilizer LM7805  The problem is the lack of power at the site of the restriction to the stabilizer LM7805 20uh
thanks for the MC34064 (leg No.2 pin) I suppose damaged control or something what do you think? :-[
Did you have 5 volts after 5 volts voltage regulator?
magpwr
hi everyone,
I have successfully created a counterpoise using tesla coil such that it is able to light 220volts 5watt bulb which is "connected to bottom of tesla coil and other end of bulb to earth eg:water pipe"
at less than 1/2 brightness using only 12volts battery which was boosted to 17volts.
I have attached this simplified circuit since i noticed there is stability problem with Akula design using 74HC14 with 6 gates.
Instead of TC4452 i am using IXDD614PI which can easily handle input frequency of 2Mhz.My experiment revealed that the TC4451 or TC4452 limitation is around 145khz.
I am using LTC1799 to generate 533khz or signal generator can be used as well.533khz is the resonance of my other tesla coil.
Using 12volts battery boosted to 17volts i able to power tesla coil using the IXDD614PI output connected via 0.33uf Mylar polyester capacitor and other pri end of tesla coil is connected to GND."Good enough for few minutes of testing"
The bottom of tesla coil is connected to Amp meter at 10Amp settings which merely reveal 17mA for lighting 5 watt bulb to earth although i can tune it to give the max current to earth ground at around 80mA but bulb won't get lit.
Question i keep asking myself should i tune it for maximum current as reflected in my Amp meter or should i tune it for maximum brightness at my tesla coil resonance 533khz
Later on i will use PWM generator TL494.Merely need to connect pin 3 from 74HC132 to pin 3 TL494 which do the job of main oscillator for low frequency.
No time to check the max frequency for TL494 yet.
Then at later stage i will need to figure out how to apply interrupter at 1.58Mhz to switch transistor like 2SC5200.
Time have run out for me since it's Sunday night over here. :D :-X 8)
Tomtech29
Quote from: Tomtech29 on March 08, 2015, 07:24:27 AM
exemplary arrangement
I checked this your idea of the problem is that this is a different scheme :o
ERROR somewhere here: (Doing this or that could work)?
for a purpose have been mixed in the TL494 pins and I can not catch what's going on?
GeoFusion
Hi guyz,
check out, how Vasmus is showing drawing on how the fields work and the resonator and everything els that is needed to know.
Circuits must be on own experimentations.
https://www.youtube.com/watch?v=h7nw_FC-kgE
Will be uploading some new stuff soon.
