0 Members and 577 Guests are viewing this topic.
bringdownthezog
Quote from: Void on March 16, 2015, 05:57:57 PM
Thanks MenofFather. Doesn't seem like overunity, as the light doesn't seem very bright. :)
All the best...
Hello Void:
I saw him measure 230 volts DC at the output in this same video at around 2:40. It's good enough for me that this circuit is charging a couple of capacitors. Even with a load. Good luck with the 'overunity' measurements.
T-1000
Quote from: bringdownthezog on March 16, 2015, 01:18:40 AM
Hello Void,
Here is all the videos Aleksei made of the Etheric Lantern. I'm not swiping his work. Rather a temporary measure until things settle down.  He has not responded so far.
https://yadi.sk/i/BbzDwBhxfGxgj
https://yadi.sk/i/fGeje8FzfGxgm
https://yadi.sk/i/tAW1jRzofGxiH
The difference between Dally/akula/Ruslan and this setup is very small:
In these videos no additional current is run through output coil. If you add it the interesting things might happen. And the Tesla coil up to the middle is run by single transistor which is making resonant only one signal to the primary coil. In akula/Ruslan videos you have low frequency square pulses driving that (they are resonant to the output).
Also the coil-capacitor plates for electrostatic current induction look interesting because as soon as you radiate signal from Tesla coil output surface "inductor" (which is another capacitor plate from my opinion) the output get charged. And the minus or large area of metal plate instead of ground is also another feature in these videos...
Cheers!
GeoFusion
Hey guyz :)
How's everything, Been busy with HHO devices, such excitement :)!
Guessing I'm done with that Alternative, I have Torch, Gas for car,
for Delco Generators if needed. oh well.
BAck to Complicated and awesome build :)
I have the recordings of the circuit  done but, need to make time to upload them in the
right order, but didn't get time to, but will ;), bit of patience guyz.
magpwr;
keep it up with the findings, only through experimenting it will be shown.
bringdownthezog
Thnx for th pics ;).
To all;
I want to share thoughts on Akula/Ruslan devices and to understand that everything around is energy and frequency,
The pictures below will show .
In Akula's first device, this is one of the most important segments within the device and after that
the Coils (HV and Antenna coiling) , Capacitive coil winding ( bifilar) and capacitors.
This gives massive induction. But as we understand it needs to be pulsed from a TL494 circuit.
Btw Ruslan is trying to replicate the Vertical Tesla coil and reciever coil device :), lets see how it goes!
He is using a super good circuit to run the tesla coil.
Will keep you guyz posted ;)
Cheerz guyz.
NickZ
    Geo:
   I've rewired my set up, trying to clean up the wiring and continue looking for that illusive resonance point.
   I see no "massive resonance",  nor massive anything, yet.  The device is still working like a low efficiency inverter, and not much else.  Not much changes with the addition of the 3 turn circuit, with the 0.47uf tuning cap, or with the addition of several earth grounds.
  I'm going to try to raise the feed-back circuit output to 24v, or so.  I may also try to use a 24v input (two 12v batteries), as well.
  I still don't understand why Ruslan wants to play with a 25w output crt, when he already had a device that produced 2300w output, and without a bunch of RF spewing all over the place.
  Looks like most of us have given up on this already...
  Good luck with your device. I'll be waiting for your video(s).
        NickZ
GeoFusion
Hi Nick :),
Yes, I see the forum being quiet for some time, never give up guyz, as an experimenter we go till it's found.
there are many other alternatives, managed some of them they work like a charm, but this one of akula/ruslan is Challenging :D.
there will be more testings, just like what I did with that Spark gap Ground learning vids I posted some month ago.
:), but did my own tests, various tests, as the pics I show above.
The lastest  akula circuit which I replicated and did test with ( first device circuit ) TL494 circuit.
You will need this TL494 circuit and a different way of setting the Fets up, it's not so difficult.
Building circuit from scratch is time, but I managed though.
Without these pulsed circuits that contain 16 pin IC's for these types of oscillations, these devices don't work.
We need to let the system sing a tone, where it matches the metal you applied it to for it to vibrate so it to release energy
Magnetic Resonance, Scalar tech :). HV HF.
Works differently as a standart mazilli / royer circuit. These TL494 circuits Act like a Spark Gapless Device :).
It can drive a tesla coil instead of a Yoke too. :).I've tried it!   it's acting as a beating heart. it sings.
So which explains why after connecting it to the yoke and reaching resonance with the cap through letting it sing and vibrate, it generates
not good voltages but good amps, and like a tesla coil needs the ground for better output, it would do the same for the yoked one.
the output should be grounded to send current
to ground and and then to receive too:).
I simply used one of my motor caps, 32uf cap 525V in series and it's constantly undercharge,  When adjusting
the variable resistor, you hear the tones change, and measuring with my meter to voltage rating ,you can see when it reaches resonance.
but try many caps, to see which fits best and better charge.
So instead of lets say 45 volts through the coils and cap after the yoke , there is 500 or 1000V charge and trapped in that coil loop.
that is where you extract power I gues :)
and did some  induction heating experiments with, heated up some iron pins and bars,
but next will be applying it on a output coiling as Akula's first.
Hope this helped as information, but I really do See with the Cap in Series and reach resonance, has alot of power.
I still have to see how I continue,
Cheerz~
