0 Members and 574 Guests are viewing this topic.
NickZ
   Magpwr:
   The reason that the AV plug will light on the water pipe, and on many other metal surfaces, is due to the capacitive link from the AC grid system.
    If I turn the breakers of at my house, the AV plug's led bulb will NOT light anywhere. Nor will there be leaked Ac power on the floor, tables, and even your own body, if barefoot.
   Try it at a friends house (as you are in an apartment), turn off his house breakers, and watch how there will no longer be any light at the AV plug, at all, when touching it to any metal surface.
A red led on an AV plug is even more sensitive to those low voltages.
   I still don't believe that there is ANY useable power COMING from the ground. Juice flows from a point of higher concentration to a lower point of concentration.  Not the other way around.
Bat1Robin2
Just remember heat pumps can somehow get over unity with heat from the ground. So why cant electricity get over unity with electric from the ground? Compress it, then use it way into the negative region, then let the ground replenish the pumping mechanism to zero level. Open systems do not fall victim to the rules of closed systems. We are in the wild west and anything goes pull from the ground pull from (NMR) matter pull from air. The trick is how to do that. Seems to be fast pulses at resonance are always a common denominator.  Bounce 2 very slightly overunity devices to each other letting it grow in power. The Tesla coil magnifying transmitter and the NMR Yoke bouncing power at 100.1% over unity to each other eventual can get what you need. Some source is from the ground some source NMR ferrite Yoke. Am i on the right track or just bouncing crap??
magpwr
Quote from: NickZ on March 21, 2015, 11:12:55 AM
   Magpwr:
hi Nickz,
In my country the electrical Earth and Water pipe Earthing is not the same.
The power supply is a 12volts battery and one chip signal generator LTC1799 was run from 12volts battery and no scope connected.It's a 100% standalone system off the grid.
However it does interfere with my battery operated FM radio placed near by in the Mhz range.
The nanosecond generator does emit small RF if i place AV plug very near to circuit.
The temporary 50Ohms resistor connected to nanosecond generator output merely suppress most of RF but it still does able to send current to Earth at  lower power.
The objective of the experiment was not about the circuit but about the use of nanosecond pulse at high voltage which does somehow induce current flow to the Earth.
Experiment reserved on Sunday is to sync this nanosecond generator to my experimental PLL base pwm generator for kapanadze winding without the use of kacher.
I am curious to know if the receiver/multilayer coil is able to pick up the nanosecond pulse from the water pipe using the scope powered by pure sine-wave inverter.
Little known fact about longitudinal wave is that the amplitude get bigger and bigger as it travel further away from the source.It is unknown to me if the signal would get reflected back from the earth core which is molten iron and back to the tuned receiver multilayer coil.
Imagine dropping a stone in a stagnant pond the circular ripples that you see which flow outwards from the source is the longitudinal wave.If you observe closely the the diameter of the ripples get larger and larger as it move away from the source.
NickZ
  Magpwr:
  You are suggesting that the AV plug lights on the water pipe in another room of your apartment due to anything but stray capacitance from the AC grid, well, I don't agree.
I can prove my point, if needed. Which may not be your point, but it is my point.
  Of course water pipes are not the same as house wiring grounding systems, in any country. Who would think that? But, the metal water pipes will pick up the stray AC from the grid. Test it yourself and see, that the AV led will light, even with no nanosecond pulses, or anything else on in the house, if the AC breakers are still on.
GeoFusion
Hi guyz :)
About the ground doubts.
use a ground pin, or a tubing that is not connected to main water copper tubing,
Nick, the ground is  a source of enhancement! Capacitive wise in my way of seeing it :).
Through my experimentations I witness this effect. never forget how a tesla coil works when connected to ground! :)
take a look akula's Tesla coils test with 2.5 load,  until he reaches resonance with the right tuning, there will be beautiful load :).
https://www.youtube.com/watch?v=1Rr-qTvTrdU
Btw guyz take my pics that i post here, This is what needs to be focused on, The resonance Circuit part.,
it's method of reaching resonance with the cap in series is crucial :). This is the part where the circuit makes alot of energy
and can work without ground ;).
check this one out.
Two pics below for  a  rough schema.
This is AKula's first device Using the method discribed in the schema.
https://www.youtube.com/watch?v=cUVvZzeDe5U
You all saw my vids with the ground experimentation and Flyback,
that was a ground pin, And started the unit also on a battery, to see if it's not mains influence.
and it functions the same. :)
Cheerz.
