0 Members and 627 Guests are viewing this topic.
GeoFusion
Hi there guyz :)
Back again for a while,
First thing want to inform that Ruslan succeeded with his next replication :). Bravo.
https://www.youtube.com/watch?v=RYjPLRQunGk&feature=autoshare
Be patient He will show you it working! :), just a tap of 12V only.
Lost_bro,
You are so close to make it work as how akula and Ruslan has. Saw your vids, Nice man, keep it up!
Those pulses are the key. but bit hard part is where tuning comes in.
Magpwr,
Nice testings man, And yes about the info about the ground , currents going thru ground, yes that needs to be achieved.
part of the Essential key to all of this :). Keep it up.
Thnx to go back into tesla's words, many hints.
Ofcourse, the more input, the higher output for sure but, we know we could go from small input and after reaching resonance it's multiplied
many times.
Remember We need to reach the Resonating point and Sync of Waves. Key 2.
integrated circuit is the only way out with this, start with  TL494's and more.. You have to need them in order to make these systems work.
But take my advice with the pics also that I provided as I tested it already ;).
Reach Resonance with the cap and the cap will reach a constant mass descharge pero mili second or nano second pulse.
Light will blink so fast you wont realise it!.
Resistance is Power.
Cheerz~
NickZ
Quote from: lost_bro on March 30, 2015, 10:37:03 PM
Hi NickZ
Is your set-up battery powered?   No mains connection at any point?
Are both incandescent bulbs?
It would be interesting to measure the amperes to ground......
EDIT;  Does the input current change when running the bulbs with the single wire/ ground wire configuration?
take care, peace
lost_bro
   My device is battery powered, but it can also be powered by my 10amp battery charger.  Sometimes I use both at the same time.  Yes the bulbs I use are 100w, 120v incandescent. But, the incandescent microwave 220v bulb lights, as well.
My meter can not read the output from my device only the input, as it's not 60hz. I use an analog, as well as a digital meter.
But, the digital meter readings go all over the place.
  The battery voltage drops quickly on my car battery for some reason, when just that is being used to power the unit.  Not sure why, as it will start a car, but my battery may be getting sulfated, as it's a couple of years old, but has not been used at all since it was new, until lately.
  Of course the input power is going to change, when only lighting a 40 watt bulb, compared to the normal 300watt load.
   I'll do some more tests today, and report back.
I still don't believe there is any real POWER coming from the ground, but it's going to ground instead. But maybe current can flow both ways, to and from the earth ground.
  I can also light a 60 watt bulb on a single grid positive 110v line, and negative of bulb to my earth ground.  But, I won't do that...
    Geo:  We're still waiting for you to SHOW us what you've done.  NO videos, no pics of your device, nothing yet.
   So, How can you be sure that the TL494 is key to allowing for the extra power?
   Did Vasmus, SR193, Kapanadze, Stepanov, and others need to use a nano second pulser crt to make their devices work?
   My feelings are that the proper heterodyning of various frequencies are the key, and not the nano pulser circuit.
   Time will tell.
T-1000
Quote from: NickZ on March 31, 2015, 10:24:25 AM
   Time will tell.
From what I've seen in akula/Ruslan/Dally methods the main thing is how you combine radiation from Tesla coil to accelerate electrons movement in coil and that goes over virtual capacitor where each plate is the coil and one of the these coils are heavily magnetized...
This is reverse from what electricity makes as it produce electrical field and magnetic field. Seems when you combine those components in proper way you can produce electricity as well without spending much effort for it. Also due radiation emitting from Tesla coil (which is electrical and alpha particles) the processes on subatomic level seem can be kicked off for energy extraction from that level.
So it is fundamental basis from my opinion how you make self runners on this category....
PS> Also with Yoke device basically there was quite similar approach to cause NMR with help of resonance on nuclear spin elevation where electrons can depart orbits of nucleus then have release of energy. The trains of resonant pulses is the key.
NickZ
   T-1000:
   And from what I've seen...   There is no NMR in these devices, at least not the kind some of you guys are talking about, with no prove to show for it.  Alfa/beta particles being emitted, sorry to disagree.  Who has done a test of radiation emitted from the Kapanadze/Akula devices? NO One... So, I think that you're barking up the wrong tree.
  If Tesla were here, he would probably not agree with that train of thought, either.
   Earth Magnetic resonance derived from the Aether, and from the power of the Earth vortex, is a different matter. And is what Akula, Kapandze and others attributed as the source extra energy.  Implosive vortex energies. Not explosive, destructive, and dangerous man made sources of energy derived from nuclear decay.
   Haven't we been through this before?
Hoppy
Quote from: GeoFusion on March 30, 2015, 10:59:17 PM
Hi there guyz :)
First thing want to inform that Ruslan succeeded with his next replication :) . Bravo.
Be patient He will show you it working! :) , just a tap of 12V only.
Lost_bro,
Magpwr,
part of the Essential key to all of this :) . Keep it up.
many times.
But take my advice with the pics also that I provided as I tested it already ;) .
Cheerz~
Hi Geo,
You are again coming across as a guy who has achieved self running and is trying to guide others. Is this the case? If so, please show us some evidence.
