0 Members and 1441 Guests are viewing this topic.
starcruiser
Quote from: NickZ on April 17, 2015, 01:19:07 PM
   As both Akula and Ruslan are using the insulated house wiring for both grenade, and the Kacher's antenna, I'll stick with that for now.
@NickZ,
I know some of them use a large gauge stranded wire but the same idea applies here as well. We are looking for similar mass of the radiator. Remember Skin effect here.
Regards,
Carl
starcruiser
Just to be clear , I am building this unit as well. I have finally gotten more free time so I have started winding my coils and collecting the parts I think I will need, currently my Tesla secondary is wound and resonates at 1.75mhz, I will pull off a turn or 2 to increase the freq to 1.8mhz. The Grenande coil portion will be wound this weekend and will be checked for its resonate peak and I will then tweak the unit to match the stages.
I will also be making the primary and radiators using the copper tubing then doing my tuning tests at that time. I will post some pictures of the various stages of build later when I am done making the coil assembly.
I will share more as time permits and show my testing and output waveforms when appropriate.
Regards,
Carl
NickZ
  What similar mass? The primary coil on the Kacher is not the same mass as the Kacher's antenna coil. Maybe I missed something.
But, my particular Kacher device will not work if I use the same size coil for the Kacher's primary coil, as the antenna coil.
I've tried it already with several primary coil tests. And I've also tried a similar sized coil for both Kacher primary, and Kacher antenna, which did not work for me. I still have that coil on hand, though, and can give another go at it, as well.
  I'm following what has been shown to work on this particular device, and neither of them (Akula/Ruslan) use copper tubing on the replications of the Akula second video device, as far as I know.  Although Kapandze and others have use copper tubing, on some generators.
T-1000
Quote from: Bat1Robin2 on April 17, 2015, 08:18:46 AM
https://youtu.be/cMMjlOBg_iY
Few things to help you out:
1) The Tesla coil has to be much longer, preferably 2x of coil length of grenade or 4x. The output voltage should be at least 5kV+
Anything with 20 cm+ away should pick up very strong field. Obviously the scope probe must be much further away otherwise it would burn out your scope. And you cannot have ground loop from driving circuit there so either disconnected UPS from mains or battery power source is required.
2) The tuning cap in series to grenade primary coil is for series resonance and the resonance frequency must be resonant even harmonics of Tesla coil (/2x, was /50 in Ruslan's case). The output voltage on cap there should reach must higher voltage level than you are powering in (most likely 10x or more). Without Tesla coil powered in it should consume lots of amps and this is what series resonance usually does. The output of second Yoke's coil over output of second coil in grenade on the load effectively should function as step up transformer in series resonance + choke without Tesla coil.
3) The effect should be at least same as in https://www.youtube.com/watch?v=qmirRN3O6Ko for a start (just the Tesla coil instead of antenna in that video) and the copper tube coil on top is actually capacitive top load of Tesla coil where the second virtual capacitor plate is grenade coil. The nature of current from the ground is electrostatic where capacitor placed in middle between charge and neutral ground source is getting charged instantly. Also the choke next to Tesla coil you seen in akula/Ruslan's video is for slight adjustment of resonant frequency between Tesla Coil and the top load so it can run on best matching frequency.
If you reach to the point where you start lighting bulbs and the current consumption drops on same time  when Tesla coil is ON then you can play around for getting greater pumping effect from the ground wire. Hopefully this helps...
Cheers!
starcruiser
Quote from: NickZ on April 17, 2015, 01:39:18 PM
NickZ,
The primary coils need to be sized to be resonate, they are tuned in a similar fashion to the secondary. Look up how to tune a Tesla coil on Google. You will need a sweep generator or make yourself on using a 555 timer ckt and a frequency counter. I have a sweep gen, scope and such thus I am tuning/ my checking coils as I go.
The output coil (antenna) would be checked in a similar manner to size it to the output (much like a CB or HAM radio setup)
The reason some are cooking their FET's is most likley due to the reflected energy, again much like a bad SWR on a transmitter due to a mis-matched   antenna, thus you burn out your finals.
Edit: added content
Regards,
Carl
