0 Members and 544 Guests are viewing this topic.
DreamThinkBuild
Hi All,
Another patent I stumbled across that may have relation, sorry if posted already.
DE 102004007134: Amplification method for magnetically controlled current amplification uses a coil in a hollow body to receive direct voltage current and manipulate electrons with its magnetic field
Translated
https://www.google.com/patents/DE102004007134A1?cl=en
Has untranslated PDF with images in the Original Document.
http://worldwide.espacenet.com/publicationDetails/biblio?CC=DE&NR=102004007134A1&KC=A1&FT=D
Enjoykin
Резонатор- спираль Василий Пупкин
http://www.youtube.com/watch?v=SgB6HJRJoG4
Опубликовано: 18 апр. 2015 г.
Василий Пупкин СЕ генератор
http://www.youtube.com/watch?v=7lDQJOAY7ks
Bat1Robin2
Nick,
Big improvement today.
https://youtu.be/VVH-BRqW_QU
I need some more advice if i hook up earth ground efficiency drops. I have tried alot of caps here and there all cause efficiency to drop. It seems like it starts up better with a small load and around 37khz or so then i move the frequency down and the bulbs get brighter to a point then i hear the yoke start to chatter and drive frequency goes unstable. The polarity of the 3 turn vs the 28 turn does decrease the output but if i reverse them both then there is no change. Im still looking for a silly ferrite rod.  I am in process of winding a bigger yoke. . Also i said in the video there was only one volt on that capacitor. my meter was on dc when i switched over to ac it was OL over 1000ac . That must be the reason for the 2.3 meg to keep that cap from blowing up. I did try going up in frequency to 70-80 khz. and i lost another FET. I was checking earth ground current it was around .5 amp, but no efficiency change accually better without earth ground at this time. I am close to the 90% in efficiency not exactly sure. look at the video and judge for yourself. The computer power supply is only powering the logic circuits very minor power. I have been installing 2200 ufd caps and trying to shorten wires as was suggested that really helped.  I need more tesla power i think. Will not even light a florescent bulb until i pulse it at much higher frequency .
NickZ
   Bat, I fixed my battery charger, but my car battery has seen better days.  I am waiting for the shop that has my new battery to replace it with a good one.
  I suggest that you place ferrite pieces inside your kacher, as they will make the cfl bulbs light up, if they won't otherwise, and,  the same with the grenade tube.
  I'll make a video tommorow. I started to make one but the camera battery was needing to be charged.
magpwr
hi everyone,
I just finish rewinding my multilayer coil but i just spotted something of interest in Akula's video.
There seems to be 4 layers for the 25 turns bifilar winding in order to get to the same height as the multilayer coil.
Which means that we are short of 50 turns since we followed Ruslan and stick with 25 turns with 2 layers.
Finally the kapanadze winding is completed as per Akula winding visual dimension.
I am sure the impedance mismatch issue using 1x 0.47uf WIMA  capacitor with 25 turns bifilar would be solved with nearly 100 turns approx 25 turns into 4 layers.
Regardless if i am using auto tuning using PLL in the previous scenario.
This is got to be around 3.5kg for the kapanadze coil using 2.5mm sq electrical wire onto 50mm diameter pvc pipe. ;D
