0 Members and 275 Guests are viewing this topic.
Bat1Robin2
In the latest video the output arrangement is slightly different than before. as shown by his paper drawings.
2 things new
1. The tesla looks like 2 fets or transistors.
2. The output arrangement is switched around somewhat.
The 28 turn winding is no longer a parr resonant but series resonant setup.
Then if you watch closely when he draws the waveforms:
The new setup will allow the 2 yoke FETs to be interrupted by the 2 telsa FETs Therefore doubling "the effect" we are seeing in the single drive tesla devices.
in another words on both top and bottom of waveform tesla coil can get an impulse. This will increase the tesla power input and decrease yet again the yoke drive input. Also this design should equal out the drive on the 2 fet on the yoke so we dont have just 1 hot FET on the yoke but both will run hot. That drawing is located 9:07 in the video. This is the reason for the new arrangement of dual tesla drive. Just my opinion. On my replication attempt the yoke drive to the FET that is "on" during the impulse will drop to about 20% duty cycle as soon as tesla is powered up. So the new one will cut them both off. so keep those fans going. The Dual tesla drive may also setup a strong standing wave as he shows in the beginning of the video not sure on what he says, i speak no Russian.
I predict in order for this to work he will need to increase the "small ringing killer coil on the ferrite rod" with more turns. Since the tesla pulses will double in numbers.
New design should make both top and bottom waveforms the same in the picture below of the yoke drive signals with about 20% duty cycle on yoke drive FETs.
The Fet being cut off from the tesla impulse not the logic circuits.
Nick, Your post is confusing im sure mine is also.
AlienGrey
The guy with the Hitachi scope, your just showing a PWM inverter, if that worked every inverter would have free energy output.
Ever come across the God frequency ? with out it you get nothing, the whole universe and nature rings with it it's a magic frequency.
Bat1Robin2
This device is 70%-80% efficient as shown on schematic and built by many on this forum some claim over 100% but keep there boxes closed. But some have not given up on this just yet. im not saying it works overunity.
But you will see the tesla impulse seems to control the pwm, most likely it brings the entire isolated ground high preventing the FET from staying on. Common power supplies do not use the radiant component of the tesla coil we are exploring here. My thought was to mix a high voltage field and a high current field in the same transformer. Hoping to get the multiplication of volt field x current field on the output. Instead of just the addition of the 2 inputs. I am still waiting for ruslan to open his boxes on a running unit.
NickZ
  Bat1:
  Ruslan has shown his boxes OPEN while running the tests showing the lighting of the smaller 60 watt bulb by itself, off of the grenade's 168 coil output.
  There are NO batteries in those boxes, please stop inventing what is not there, as it's getting really boring and annoying to hear about it each time you post. If you think that that is what is going on, then WHY are you doing this replication???
  This test mentioned above, was done when using the Kacher's impulse, as well as output from the 3 turns coil/resonator coil, only, while his input is 24 volts from two 7ah 12v batteries. This is what I'm working on now, and I don't see what is confusing.
As without having this part of the device working properly, the rest of the device is just a very low efficiency inverter.
He shows how a small change of 100khz or less from the optimum frequency, can totally change what happens at the output of his  test bulb. So, unless you really hit the nail on the head, with the two running frequencies, there is no improvement at the output, and maybe it can possibly even interfere with it instead, like what you may be seeing on your scope.
  BTW:  Looks to me like Ruslan is using a smaller yoke on his latest device as well, similar in size to the one that you're using. Which is not the same as the one that is normally used, the 3 inch size yoke.
magpwr
Hi everyone,
I have made important discovery today on why previously i was able to obtain similar effect to URFA although my circuit with toroid only consume <30watt with a 60watt 220volts bulb dimly lit(Not rectified the last round).
I live in a tropical island in the heart of the Asia like a tiny Gem in the Ring.The humid level is little high over here.
Since i am trying to setup all over again on the floor and run shorter wiring to the primary winding of Basic EMP generator(Tesla coil with spacing) to reduce lost and increase nanosecond pulse in kv.
Apart from the improvement around 7KV from EMP generator up from 6.48KV from the previous 1st actual experiment with long messy wiring."Photo attached"
This is the latest discovery and i think this is the important one while trying to perform test run on the nanosecond generator after setting up on the floor.
Today i have confirm there is some kind of static buildup on the Antenna or even after the EMP generator(Tesla coil) output long after power is switched off.
I placed the test pen on the Antenna and noticed the usual neon glow.But wait a second the power to 12volts battery was disconnected and the circuit is no longer functioning.
There was only small residue charge on the pulse capacitor around "140volts" since mosfet is no longer switching.
To confirm there is static buildup at tesla coil output or Antenna my test pen is able to stay lit for nearly 2minutes long after power is disconnected.
I am sure if the same test was conducted in a low humid environment the test pen would able to stay lit longer.
But that's not the important point.
This is likely why URFA and myself is able to achieve the similar effect although my setup uses less power than his for my version 1.0 experiment.Tomorrow i shall perform another test and upload a video
to youtube.It's been a long time since i last upload video to my youtube channel "sanjev21"
I have attached link to URFA youtube video related to the bulb fading effect i am talking about.This effect was not seen in any other video including Russian members in a another forum.
http://www.youtube.com/watch?v=vfrFmM8eh2A
The last round of experiment conducted last week since it was late i have not taken the frequency or waveform as i was still at tuning and discovery stage.
