0 Members and 144 Guests are viewing this topic.
ATOM1
Why is there so much uncertainty as re building these generators ??? Surly there must now be a standard formula ??? and a simple reliable diagram ???? As I see it increasing frequency drops the need for normal current to emit photons from a load and the system is just in feed back mode...
I had some luck with a 2 amp 240v varyac transformer it was old with a rusted core and stored a charge and would power a small universal motor when the plug was taken out ...  Earthling was important THE VOLTAGE WENT THROUGH THE ROOF WITH ITS FREQUENCY..... ????
There was no other parts !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Atom1
NickZ
  Ruslan has shown how the 60 watt bulb will light up brighter, when the Kacher circuit is also connected up, when he places the fuse into the fuse holder.
But, he has never shown the yoke/grenade push/pull part of the circuit running by itself, and, then attaching the Kacher circuit, to show the difference in output, when
running ALL of the bulbs (1000w, or so).  That, I'd like to see.
   Tomtech:  How many bulbs have you tried on your circuit?  How many amps worth, and what voltage?  120v, or 220v?
a.king21
Quote from: ATOM1 on June 11, 2015, 09:43:44 PM
Why is there so much uncertainty as re building these generators ??? Surly there must now be a standard formula ??? and a simple reliable diagram ??? ? As I see it increasing frequency drops the need for normal current to emit photons from a load and the system is just in feed back mode...
I had some luck with a 2 amp 240v varyac transformer it was old with a rusted core and stored a charge and would power a small universal motor when the plug was taken out ...  Earthling was important THE VOLTAGE WENT THROUGH THE ROOF WITH ITS FREQUENCY..... ??? ?
Atom1
How long did the motor run for?
Have you got a photo or video?
Grumage
Atom1
Dear Atom 1.
You do realise that your post represents the equivalent of dropping of an Atomic bomb?  :)
Pun intended!!
Seriously, do you still have your experiment components available to provide a video of the phenomenon you have referred to?
In anticipation.
Cheers Grum.
Void
Quote from: ATOM1 on June 11, 2015, 09:43:44 PMAs I see it increasing frequency drops the need for normal current to emit photons from a load and the system is just in feed back mode...
Hi ATOM1. You have obviously been influenced by the work of Marvin the Martian.  ;)
All the best...
