0 Members and 410 Guests are viewing this topic.
Bat1Robin2
Use a standard generator at first to slowly dial thru the frequency range. from 15 khz to 60 khz or so... ideally i found 27khz area was most efficient 72%. Going too high in frequency will damage fet in that schematic, going to low will simple loose efficient output and not light bulbs. Several large efficient peaks can be found throughout the range.  Small peaks as you hit the timing of the high frequency tesla impulse just right on each ring down peak.   S1 is wired wrong it wont invert in that schematic. The 4046 circuit is designed to lock into anything in that  range i believe. I found the feedback signal is not a smooth sine-wave, so it has trouble locking all the time. But then how could it be smooth feedback with 3 coils all mixing in the air transformer. With a Tesla impulse and the high frequency ring down. The sine wave can never be smooth when its being hit with that massive impulse making locking of the 4046 a ridiculous design. But it somehow shows lock once in a while from the Leds.  I do not think this is the schematic to follow. But if you like adjusting tuning caps for days on end with no results over 72% go for it. I think an arduino controled vco would be better choice you could put more programming into the arduino to help filter the junk noise feedback. Just an idea for someone else, im convinced myself after days of tuning caps its a bad design but only throwing ideas out, trying not to be negative.
Dog-One
Quote from: Bat1Robin2 on June 27, 2015, 01:59:45 AM
The Type-II setup here will lock on rising edges.  The feedback circuit shown is designed to magnify whatever signal is present on the current sense transformer (toroid).  It then clip the tops and bottoms off that signal with the two diodes, so it's no longer a sine wave anymore.  It then toggles between high and low at the zero crossing via the comparator.  In order for this type of feedback signal to work, you need considerable amperage on the sense wire and lots of turns on the pickup toroid.  The polarity of the current sense toroid is also critical.
Again, like I alluded to previously, this is a complicated device.  Understanding why Ruslan would want to phase lock at the zero crossing (either going high or going low--not sure which), is a bit of a mystery.
I put the above circuit together to do a little testing and noticed the minimum frequency is about 6kHz.  I think somewhere in the latest few videos he mentions the device operating at 15kHz, clearly lower than the 27kHz many thought was the sweet spot.  So we know he built a frequency range into the circuitry for a reason and it appears by adding/changing capacitors on the energy side of his device, better performance can be achieved.  This also gives me the feeling all the talk about wire length in the coils isn't absolutely correct.  It's probably more important that the ratios are good, but the frequency can be adjusted as needed using capacitors.  You may also notice in his latest videos, he has a large gob of capacitors all soldered together in the box with the yoke coil glued to the lid.
Also interesting is that he now uses instead of a single pulse to the Tesla coil, he uses a burst.  This can be easily achieved with a simple gate driver that has an enable (acting as an AND gate) and the Slayer Exciter circuit attached.  A word of caution though, you will need a heatsinked gate driver to run effectively in the MHz range and a separate (ternary) winding on the Tesla coil as the feedback.  That way you can still hard ground the base of the Tesla coil secondary as Ruslan stresses.
Now if only Ruslan himself would come on this thread and tell me I'm wrong and what I should do instead...
AlienGrey
AlienGrey
This is what i slung to gather a HEF4046 and an buffered inverter going to 2 Red leds and a |Tesla coil so i can get the best passive resonance frequency in tune with the universe so to speak (don't want any energy from the Dark side) ;) also the cap across pin 6 and 7 is missing on my circuit as i need a high freq with that coil i have, from what you all have in the Ruslan device must be about 6 Mhz or 1/4 wave but still 6mhz fundamental on the Tesla coil. To get 1Mhz5 you will need a good 1250 T on a 50mm drain pipe in the material world, pulsed or not to get it all in resonance or your pissing in the wind, like it or not ;).
AlienGrey
Bread board lashup notice pins 6 & 7 are floating, Leds not shown on circuit, but fully in resonance here and brilliantly lit from pin 4 to buffer chip like TK said could use 4049 all in parallel coil on left is just a Tesla coil.
