0 Members and 256 Guests are viewing this topic.
NickZ
  It's like looking for a needle in the hay stack.
  Maintaining the device at the right running frequencies, is another thing.
  So, do we even know if Ruslan has discontinued the use of the PLL? Or is he's doing something similar in another way now?
As he likes to play around with many different circuits. Which all happen to work, or so it seams.
  Ruslan has already changed from the original grenade output coil of 37.5 meters long, to 40 meters,  now. And, may have also changed the ground line to 40 meters, as  well. This may account for the running frequency to drop, from 27.3khz, to 15khz. And his Kacher is now at 1.5mhz, down from 1.7mhz. And, so, what wire size to harmonics are we dealing with, now.
Hoppy
Quote from: T-1000 on June 29, 2015, 06:54:18 AM
The tuning point is very precise and +/- 100kHz makes entire setup out of tune. The clean sine wave with sharp resonant peak (which is sine wave on quarter or half of 37.5m wavelength) is your target. The 15W bulb as load on grenade coil output should be good lit when running device from only from Tesla coil.
And you should realize effect as soon as it hits on right spot...
Hopefully this is helpful transcript.
Cheers! :)
Yes, I've seen the 'effect' - a surprising and sudden increase in output efficiency - due to the push-push transistors being non-symmetrically switched, causing one FET to shut-down as previously reported by Batman.
NickZ
  Although that effect may happen often, it does not account for the 4000w output shown by Ruslan's device.
  Something other than stuck fets, or hidden wires or batteries, are at work there.
  I also find it interesting that a device made to run on 24v, (or from it's own 24v feed back loop), can be jump started using only a small 9 volt battery.
  My push-pull oscillator will continue to running with only 7-8 volt input. But, only with a small load bulb on it.
NickZ
  I'm glad that we can agree on something, even if it may be for the wrong reasons.
