0 Members and 406 Guests are viewing this topic.
verpies
Quote from: AlienGrey on June 28, 2015, 08:01:12 AM
...i can't understand how that waveform can be generated from the circuits at this moment, as the sine wave peek goes positive at the top a huge positive EHT spike is generated and on a negative sine wave peak is generated on the reverse polarity a negative EHT spike is generated, are you with what I'm showing and saying ?
Have a good look at this photo your self, and think about what's suppose to be happening ?
Ferromagnetic saturation is happening.
You can achieve this type of waveform by attaching  your scope across P1 (red terminals) and keep decreasing the resistance of P1.
When the resistance of P1 becomes low enough, high current will flow through L1 and its ferromagnetic core will become saturated at both sinewave peaks, its relative differential inductance will fall to 1 then ...and these spikes will appear on the scope.
The same thing will happen with transformers.
P.S.
The little squigglys at the peaks of the clean sinewave are much more interesting than the big spikes on the other waveform.
NickZ
  I had wound my Kacher's secondary coil longer than it needs to be. So, that I can tune it later by removing some turns.
So, today I removed about 1/3 or the windings, but there was no difference, and I still can't get any influence from the Kacher to the grenade coils.
  If the right frequencies are only to be found at a very narrow band width, I may not see any difference until I'm right on the money.
  I'm still waiting for my scope.
AlienGrey
If you bother to read Ruslans forum, it is in Russian but it tells you everything, your not reading it or you wouldn't have all this trouble, some of them say they have got them working and Ruslan does explain secrets, the unit you have should be a katcher of 2 mhz not 1.7 or 1.5 mhz.  I my self have not got any hardware as such just yet. I like to  R T F M first ;)
PS if you know F look up the wave length then find out the length for say about 10 turns round your former then you can work out how many turns to need buy dividing that into the wave lengrh for your coil to be spot on.
Dog-One
Quote from: T-1000 on June 29, 2015, 01:22:24 PM
For PLL or no PLL there's reason. Without it you have to tune on exact load and ground, air ionization conditions then with that changing the resonant frequency shifts and system goes out of tune.
Ruslan always use PLL for making tuning much easier.
I think this can be done without PLL, but if you attempt it, you must use a fixed load and the power source you start the device with must be pretty close to the same output as the loop power supply that keeps the device running.
Bottom line...  I would recommend using the 4046 regardless, just for the VCO.
Verpies,
The only core used in this device is the toroid yoke and you feel quite certain this is being saturated.  Meaning...  You are pretty confident NMR comes into play here?  So what frequencies might be responsible?  Both the kHz and MHz?  Maybe heterodyning in such a way to spontaneously promote NMR in the core?
DA1
Quote from: NickZ on June 29, 2015, 11:57:38 AM
  I aim to find out...  even if it's the last thing I do.
HI NickZ  All   from thai land
สวัสดี Nickz  และ ทุกๆท่าน   จาก ประเทศไทย (thai land)
I am glad that you are committed to do.
ผมดีใจที่คุณมีความมุ่งมั่นที่จะทำ
I believe you can do and do well.
ผมเชื่อว่าคุณทำได้ และ ทำได้ดี
