0 Members and 73 Guests are viewing this topic.
itsu
@All,
i put all components on 1 tray, including an ATX PS which feeds it all.
Now the big tuning can begin.
Both the tl494 and the nano-pulser are at about 4.2Khz (resonance of the L2 coil)
At the moment i am at 1/10 of the needed output (22V DC), so still a long way to go.
Sweeping through the frequencies does not show any sweet (hot) spot yet.
Video: http://www.youtube.com/watch?v=mDd8hdNZIqo&feature=youtu.be
Regards Itsu
T-1000
Quote from: itsu on December 02, 2012, 05:41:02 PM
@All,
Regards Itsu
Thanks Itsu for hard work.
Also there is small problem: your nanopulser is making spikes in both ways at once over sine wave and that is killing process... You might try to adjust it at least for half wave and try to get shooting it on top of sine wave or into opposite but not both ways.
Cheers!
verpies
I put all components on 1 tray, including an ATX PS which feeds it all.
It's odd that the nanopulses are getting out of the coax and influencing the other windings.
In an ideal coax all of the fields should be contained inside of it.
That's the first anomaly ...or a leaky coax.
Do the nanopulses on L1 or L2 disappear if you disconnect the coax (L3) ?
T-1000 seems to be implying insider's knowledge about this system thus it might be prudent to try his suggestions at this stage.
If you run out of options, I can help you to connect the output of U1 to U3 via some resistive dividers in order to achieve perfect phase synchronization between the L1 sinewave and nanopulses.
Black_Bird
@itsu:
I had about the same voltage at L4, then I made L1 in a cardboard cylinder so I could slide it in and out of the other three coils. That made a huge difference, and now I can get almost 160V at L4, depending on how much of L1 goes inside the other three coils. I think your L4 has more turns than mine ( mine has 59 turns), so, it is likely that you'll be able to get the 200V.
Another thing I did was to connect a wire in the VCO, at the junction of the two 1 K resistors that go to the frequency adjustment pot, and I just wound that wire on one of the wires that go to L1( to get some capacitive coupling) and I could synchronize the pulse with the top of the sine wave in L4. Then, I started to get some strange waveforms, mainly a low frequency modulation, which I'm trying to understand now.
Сергей В.
Itsunadze привет !!
You are now on targeting!!  :D
I was watching your video. Good to see that all you need you have completed and putted on your desk. Why don't you put your videos in public so many people can watching it. It very interesting to all who enjoy in electronics especially Free Energy researchers.
I will try to help you with timing from Tiger2007 ou-generator 150-200Watts. I sent a message to Dally to answer me on some important questions. Still now i haven't contact from him. I still expect his oscillograms and some important measurements. Will see what's will happened very soon !!
BTW in my opinion problem with all replications is absence of "Syncronization" between master oscillator and Nano-Pulser. I studied Tiger2007 schematic and i found precise syncronization in his ou-generator.  Also many other r esearcher schematics have syncronization. Imagine you are in war for example Alien reptiles-anunnaki and you shooting on your enemy randomly without tarheting. What is probability to kill any alien on that way. Very very low. So in that and in Dally case you need a precize targeting!
Look at Tiger2007 schematics and try to do exactly on his way. Go on Antanas site on Tiger2007 thread and watch some Tiger2007 videos. For example Tiger2007 economizer.
http://www.youtube.com/watch?v=jwH_xOA2ajQ
Link is http://freeenergylt.narod2.ru/tiger/
Tiger has used ferrite in his generator and you using Coaxila cable. It's a big difference but i think you have pretty good understanding of process and skills to finish your job. Even if you success to get 40-60 Watt of Free energy it isn't mean that your work was finished.  No need to stop untill you can harvest several KWatts of Free Energy. I wish you success.
ps. Remember Dally have a problem with looping his OU generator. From 6 Power Supply Units he found only one which have finished looping job. I still don't know correct frequencies on his generator. Also will be good to try grounding on different points of your coax, from input and output side and try pulsing not central conductor but shielding cooper braid. (with and without grounding central conductor or end of coax where conductor and coax make single conection. In any case need some additional Time-domain reflectometry experiments but not to mesure reflections of pulses, to extract as much power as you can.
Also take atention BlackBird idea to make L1 coil movable through the other three coils. Try for the fisrt time to put and slide some cooper rods or better ferrite rods just for experiments.  Also if you can turn off Nano-Pulser and measure output without excitation of your coax.
I have readed on Realstrannik forum and found some interesting syncronization schematic from Realstrannik memeber SE-TPU. Link is: http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/81877-kak-nanosekundnyj-generator-sobrat-i-nastroit.html?limit=18&start=702
It's a simplest zero-crossing detector which monitor voltage on coil #3 on TR2 (Transformer2) and give +5V pulse on each zero-croossing waveform. Pulse going on pin 1 of КР1554ЛА3 and start Nano-Pulser. In my opinion syncronization pulse need to be produced from coil #4 Tr2 which is infact L1 coil because coils 3 and 4 are out of phase to each other. But maybe the best way for experiments is to get 2 zero-crossing detector on coil 3 and 4 respectively. You can add some pulsing dealy networks in form of simple differentiators RC networks for trimming initial delay. In any case detector have only few components more but give you a great chance to start REAL-OU-SHOW. As you Americans says SHOW MUST GO ON !!
Regards Сергей В.
