0 Members and 363 Guests are viewing this topic.
Dog-One
Quote from: John.K1 on July 08, 2015, 04:15:41 PM
What I could catch with my poor Russian from the Ruslan's last movie:
Thank you John.  Very helpful and matches pretty close to what I was able to discern.
I'll also say, if you are not carefully replicating while understanding what you are doing while you're doing it, none of this going to make any sense at all.  But if you are trying to learn as you go and understand what you are doing and why, the pieces start to fit together nicely--almost exactly like Ruslan says.  Imagine that.
Zeitmaschine
Quote from: T-1000 on July 08, 2015, 02:33:01 PM
if he would make one generator for you then you would take it apart and put it back that will stop working because after that process the values of coils,etc would be changed and you would never would be able to run it again without understanding how to tune it...
That's a good excuse. Means: If you can't get it to work, then because you are to stupid to do so and not because his device is phony in the first place.
For a strange reason such devices always come up on youtube to be watched, but never on ebay to be purchased. Why is that so? Ideas?
Void
Nick & other.
1. Do not ask for any help. Start to understand the process.
2. The process is very basic and simple Resonant circuit (LC?)
3. Understand resonance circuit!! (2 resonant cuircuits)
4. Stop talking nonsense about the TV choke. Any high frequency toroid core will do fine. Akula had just TV choke at the hand .
5. He is not using Kacher. He is using SG based on TL (pulses)
6. System works on the principle of mixing frequencies
7. The Grenade coil is NOT a Kapanadze coil!!! It is just regular transformer
8. Big coil is the collector. other two coils forms resonant circuits
9. Learn to understand resonant transformer and its tuning!!
10. Tesla's bottom wire connected directly to the ground
11. Ground cable  MUST BE THICK wire
12. No grounded PowerSupply
13. Ferrite rod was used for fine tuning of synchronization- is not necessary if frequencies are synchronized other way.
Also lots of offending the replicators like we have no brains, just waiting for schematics instead of understanding process, sitting, waiting and doing nothing etc...
Tha's all folks ;)
Thanks for the translation John.K1. As much as I think Ruslan is playing games for whatever reason,
he also seems to possibly really have figured this thing out, but there are various inconsistencies that
keep coming up.  If the grenande coil is not a 'kapanadze coil', then why is it wound just
like Kapanadze wound it? ;D Ruslan has contradicted himself or said very strange things a number of times now.
In the past Ruslan has demonstrated using a wire that was not very thick for the ground wire, yet he now says the
ground wire must be very thick. Ruslan must be a real life Russian/Latvian version of Batman's 'the Joker' or 'the Riddler'. ;D
Here is my own assessment of Ruslan's Akula replication up to this point. It is just my ideas on how it might be connected together now and tuned and working.
Some of this is just guessing and may need to be corrected based on things Ruslan has said recently in his latest videos.
I am working on other projects these days so I won't be trying this right now, but I may come back to this once I am done with the other projects. :)
Latest Ruslan replication construction and tuning according to Void's observations and best guesses:
PWM generator tuned to 15 kHz.
Series resonant circuit with series capacitor from yoke output winding to primary 'inductor' winding over the grenade coil is tuned for series resonance at 15 kHz.
Tesla coil primary is no longer driven with a 'kacher driver', but is instead driven with a series of pulses (gated pulses) timed to coincide with the peak of the
15 kHz sinewave in the series resonant 'primary' circuit.
The grenade coil is cut to a wire length of one quarter wavelength at 1.5 MHz, which works out to 50m (if you ignore velocity factor correction for the wire length).
--->  Did Ruslan say he is now using 50m for the grenade wire length, or what length did he say he is using now?
The tesla coil is tuned to resonate at 1.5 MHz with everything connected to the tesla coil.
The bottom of the tesla coil secondary is now connected to the earth ground wire connection only.
The question then arises, are the series of gated pulses driving the tesla coil primary timed to coincide with the 15 kHz sinewave voltage peaks, or the current peaks, on the 'inductor' winding?
My guess would be that the tesla coil output pulses may be timed to coincide with the 15 kHz sinewave current waveform peaks on the 'inductor' winding.
Why? Because my thinking is the PWM driver circuit driving the series resonant primary circuit is there to create a current of high Amps.
The series resonant primary circuit not only creates a higher voltage on the 'inductor' winding, it creates a much higher current through the 'inductor' winding.
Akula has said and demonstrated this himself in his earlier videos in regards to using the series resonant circuit to create high current.
Applying the output pulses from the tesla coil 'antenna' winding at the 15 kHz current waveform peaks (positive peaks only?) causes some sort
of synthesis/multiplication to occur, which combines/multiplies the high current waveform from the PWM generator with the high voltage output pulses
from the tesla coil, and, voila, you have the product of these two waveforms combined/synthesized into a new high power waveform on the grenade coil.
The earth ground wire must be a thick wire going to a really good earth ground, and where earth ground is all connected in the circuit I am not exactly sure now.
--->  Does the earth ground connect to both the primary series resonant circuit somewhere and to one side of the grenade coil?
It seems that it does in earlier versions. Earth ground also now goes to the bottom of the tesla coil secondary, as mentioned above.
--->  So, is the earth ground connected to all these three different connection points now?
The earth ground wire must not only be thick and connected to a really good earth ground, but the length
of the earth ground wire needs to be fairly long based on various Akula and Ruslan videos, and it seems
the ground wire length may need to be cut to a quarter wavelength of 1.5 MHz, which is 50m.
--->  In Ruslan's latest videos, does it look like Ruslan's earth ground wire could be 50m (164 feet)?
There you have it. I could well be wrong about some/much of this stuff, but that is my best observations and surmising and guesses.
Good luck to everyone, and keep us posted if you have any interesting results. ;)
Keep on smiling. :)
AlienGrey
Hi John K1, thanks for your informative detailed list, a lot of your info helps confirm a good bit of what Ruslan and others have said in the recent past, I'm a bit confused on line 5/. where you refer to," He is using SG based on TL (pulses)".
I and possibly others will be fine if you can un-abbreviate the abbreviations, and thanks very much.
Void
AlienGrey, Ruslan has been using a gated pulse train generator to generate a set of gated pulses to drive the
tesla coil primary, timed to coincide with the 15 kHz (current?) sinewave peaks.
SG most likely stands for signal generator. :)
